1050 dominator enough? #614306
02/15/10 10:43 PM
02/15/10 10:43 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
440, 4.15 stroke, 10.5 to 1 comp, 650 solid roller. indy ez cnc'd, indy single plane, 2inch headers. Motor is in my strip only car, 4.56 gears, 3200lb. will a 1050 dominator be enough or will I need a 1150?
Re: 1050 dominator enough? [Re: 68gtxsurvivor] #614307
02/15/10 10:46 PM
02/15/10 10:46 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am sure that is enough.will you be running a filter on it?
Re: 1050 dominator enough? [Re: blownzoom440] #614308
02/15/10 10:58 PM
02/15/10 10:58 PM
Lexington,VA
Lexington,VA
not when I make a pass
Re: 1050 dominator enough? [Re: 68gtxsurvivor] #614309
02/15/10 11:02 PM
02/15/10 11:02 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I had the same setup and my 1050 was just fine... I had 11 to 1 though... street/strip car and 4.10's
Mopar Performance
Re: 1050 dominator enough? [Re: 68gtxsurvivor] #614310
02/15/10 11:13 PM
02/15/10 11:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How many RPM will you be pulling... as the RPM goes
up so should the cfm
Re: 1050 dominator enough? [Re: MR_P_BODY] #614311
02/16/10 12:01 AM
02/16/10 12:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've been trying to work out what size dommy i need on my junk but every manufacturer has a different idea & every calc for working it out gives me a different answer. was thinking of buying a king demon with the removable sleeves so if i get it wrong i can change relatively cheap.
Re: 1050 dominator enough? [Re: 68gtxsurvivor] #614312
02/16/10 01:15 AM
02/16/10 01:15 AM
We ran a air volume sensor to determine volumetric effeicncy on the 572 C.I. motor Rodney is testing on the dyno now, it has a custom built 1150 Dominator on it and the sensor says the motor is using around 1030 to 1040 CFM at and above 5000 RPM to 7000 RPM I used a Holley 9375 HP(nothing bigger) on a motor very much likes yours with ported 346 heads and it ran faster with every bigger carb. I tried on it A good 1050 will work very well, IMO
