sm block herbert roller lifter??pics added #614149
02/15/10 06:04 PM
02/15/10 06:04 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
just got my herbert solid roller lifters for my small block stroker,which way does the lifter link go?mike
Re: small block herbert roller lifter?? [Re: hp340nos] #614150
02/15/10 06:11 PM
02/15/10 06:11 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Link bar goes on the cylinder side of the valley.
The v in the bar would point towards the carb if it was there.
Re: small block herbert roller lifter?? [Re: RobX4406] #614151
02/15/10 06:16 PM
02/15/10 06:16 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
herbert had told me the opposite on the phone,thats why i was questioning it.i dont have the heads on it yet to check pushrod angle.
Re: small block herbert roller lifter?? [Re: hp340nos] #614152
02/15/10 06:17 PM
02/15/10 06:17 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Are those the Drop-im lifters?? If so,can you post some pics??
Re: small block herbert roller lifter?? [Re: MIKES_DUSTER] #614153
02/15/10 09:04 PM
02/15/10 09:04 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
mikes duster;yes drop in stylelifter, i will post some pics ;it wont be until after 11;30 when i get home from work.
Re: small block herbert roller lifter?? [Re: hp340nos] #614154
02/16/10 01:14 AM
02/16/10 01:14 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
another pic
Re: small block herbert roller lifter?? [Re: hp340nos] #614155
02/16/10 06:08 PM
02/16/10 06:08 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
bump for mikes duster
Re: small block herbert roller lifter?? [Re: hp340nos] #614156
02/16/10 07:15 PM
02/16/10 07:15 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
When you drop them in you see why the V points towards the carb. It is there to clear part of the block where a straight T-bar won't work.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: small block herbert roller lifter?? [Re: Irun5snd8th] #614157
02/16/10 07:30 PM
02/16/10 07:30 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Will those pushrod oil? Anyone running these for a Mopar with success?
Re: small block herbert roller lifter?? [Re: DaKuda] #614158
02/16/10 10:00 PM
02/16/10 10:00 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
No on the push rod oil. I have had them in since 08 with no problems yet
Re: small block herbert roller lifter?? [Re: hp340nos] #614159
02/17/10 01:14 AM
02/17/10 01:14 AM
Thanks HP!!!! Can you post some pic with them in your block??
Re: small block herbert roller lifter?? [Re: MIKES_DUSTER] #614160
02/17/10 02:06 AM
02/17/10 02:06 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I know on my 360 block i had to do some minor grinding with a die grinder to get those lifters into the lifter bores. the lifters adjacent to the #8 cylinder took the most work, but it wasn't anything i'd worry about or wouldn't do again.-Andy
Re: small block herbert roller lifter?? [Re: 340_Dart] #614161
02/17/10 09:06 AM
02/17/10 09:06 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I had to grind the block to get my comp 828's to fit. I think that is standard practice unless you get the MEGA bucks new reverse bar lifters. I will always wonder why turning the bar around adds $200 to the price of a set of lifters.....Looks like Herbert has some business coming his way.
