Mopar Perf Electroniic Ignition wiring 2 EBody harness #614131
02/15/10 05:54 PM
02/15/10 05:54 PM
Texas
bogusracer Offline OP
Texas
What all is involved in wiring in a Mopar Performance Electronic wiring harness & distributor into a stock TA 340 Six Pack car. I don't want to modify the existing harness, just want to build a harness I can plug into existing plugs and have it work with the 2 post ballast resistor. Is there anyone who can illustrate what to do with the proper wire color codes etc.?
Thanks in advance for your help.
Bogusracer
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: bogusracer] #614132
02/15/10 07:21 PM
02/15/10 07:21 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
use a petronix ignitor II and the flame thrower coil.
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: 05dakota] #614133
02/15/10 08:36 PM
02/15/10 08:36 PM
Texas
Texas
Not an option at this time ... Owner wants a Mopar performance unit so it Ma Mopar only. Thanks though.
Bogusracer
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: bogusracer] #614134
02/16/10 01:54 PM
02/16/10 01:54 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
then you will need a factory wiring diagram and build your own conversion harness
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: bogusracer] #614135
02/16/10 01:57 PM
02/16/10 01:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If you call M+H they can build a harness with the electronic ignition upgrade built right in and still retain a factory look, no need to modify anything. That way at a later date if the owner decides to return to OE stock, it's just a simple harness swap
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: gtx6970] #614136
02/16/10 02:29 PM
02/16/10 02:29 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Where are you puting the "box". Where is the best place to put it? I'm working on an AAR and thought of attaching it to the firewall inside the car. What's the best way to hide the wiring to make it look stock? I don't think you can use the Pertronix unit on a dual point distributor such as the T/A and AAR.
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: bogusracer] #614137
02/16/10 03:15 PM
02/16/10 03:15 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
Al & Sheila
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: gtx6970] #614138
02/16/10 04:09 PM
02/16/10 04:09 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I just called them asking about Year One wiring harness HU10AEM "1970 340/6 with electronic ignition upgrade" and they advised that harness is set up to have the ECU mounted on the passenger side firewall, just like the later factory electronic ignition. They WOULD NOT make a custom harness to mount the ECU elsewhere out of sight.
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: 3twos] #614139
02/16/10 04:32 PM
02/16/10 04:32 PM
Texas
Texas
Great Help !!!! Thanks so much .
Bogusracer
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: 3twos] #614140
02/16/10 04:37 PM
02/16/10 04:37 PM
Texas
Texas
http://www.moparts.org/Tech/Archive/elec/3.html
Contacted M&H they said that Year One would have to grant permission for them to make any Mopar harness because Year One owns all of the tooling. Even if it was a custom unit that uses Mopar specific connections, Year One would have to O.K. it.
The Tech article is just what I need and I'll go from there.
Thanks,
Bogusracer
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: 6pkaar] #614141
02/17/10 11:32 AM
02/17/10 11:32 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
I find it asinine that so many people build 100 point OEM show cars, only to stick the orange control box on the firewall.
Uggghh...
Don't see what's so bad about using Pertronix unit. Hidden and it looks stock.
If you have to use the Mopar unit, then just get a whole new harness w/the built-in wiring for the control box.
Problem is that it utilizes the four-prong ballast resistor which doesn't look stock either!
As far as mounting...don't know about small blocks, but for big blocks, you can mount the the box on a the rear intake rail.
http://www.rocketresto.com/electronicignitionbrackets.html
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: bogusracer] #614142
02/17/10 12:01 PM
02/17/10 12:01 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
The biggest reason that M&H won't make a custom length harness is that the ECU was designed for a specific length of harness, Anything over that length can cause really wierd problems.
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: BJohnson] #614143
02/17/10 12:33 PM
02/17/10 12:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I agree , especially over time. The ECU was designed to work with a predetermined amount of resistance, changing this resistance will cause issues over time
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: gtx6970] #614144
02/17/10 03:19 PM
02/17/10 03:19 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
OK, so If I get the 1970 harness that's made for the "upgrade" to electronic ignition, where will that allow me to hide the ECU? I don't have a harness now to figure this out. I bought the car torn down and I'm in the process of restoration. My understanding is the Pertronix unit cannot be used in dual point distributors (this is on an AAR), so I purchased a Mopar Performance set up. What have all of you done that have changed to the MP distributor and put the box out of sight?
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: 6pkaar] #614145
02/17/10 03:41 PM
02/17/10 03:41 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Bill Evans can make you a custom harness to use the Mopar ECU
He has done several for me over the years, I usually mount the control box underneath the battery tray. It's cool, and gets good airflow from the front of the car.
It's also not immediately obvious unless you see the two wires coming off the distributor instead of 1.
Another alternative is to put the ECU inside the car, but then there are issues of heat to consider.
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: 6pkaar] #614146
02/17/10 04:24 PM
02/17/10 04:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
In the same place as mother mopar designed it to be mounted, just off center towards the pass side of the firewall
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: bogusracer] #614147
02/17/10 05:26 PM
02/17/10 05:26 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
why is there a modifying your mopar post in a restoration forum? ? ? ? ? ? ?
am i missing something? ? ? ? ? ?
Re: Mopar Perf Electroniic Ignition wiring 2 EBody harness [Re: joelson6] #614148
02/17/10 09:25 PM
02/17/10 09:25 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Read my post above.
Use the Rocket Resto bracket to hide the ugly orange box.
