440 Source Stealth aluminum heads - any good? #61403
05/22/08 12:57 AM
05/22/08 12:57 AM
Central CA
K
KAHUDA Offline OP
KAHUDA  Offline OP
K
Central CA
anybody got an opinion on the new Stealth aluminum heads from 440 Source?
$899 fully assembled almost sounds to good to be true.
Re: 440 Source Stealth aluminum heads - any good? [Re: KAHUDA] #61404
05/22/08 01:29 AM
05/22/08 01:29 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Do a search I'm sure you will find more than enough info.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 440 Source Stealth aluminum heads - any good? [Re: HealthServices] #61405
05/22/08 05:39 AM
05/22/08 05:39 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
My friend just had a 505" built. Ran on the Dyno with Stealth heads then tested with Eddy's. The Eddy's made 40 hp over Stealth. Hope this helps.
Re: 440 Source Stealth aluminum heads - any good? [Re: maximus] #61406
05/22/08 12:12 PM
05/22/08 12:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
not enough info .
were the heads the same , meaning both were run out of the box or ???
inquiring minds want to know
Re: 440 Source Stealth aluminum heads - any good? [Re: KAHUDA] #61407
05/22/08 12:14 PM
05/22/08 12:14 PM
this is getting sooooo old
Re: 440 Source Stealth aluminum heads - any good? #61408
05/22/08 03:59 PM
05/22/08 03:59 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
They better be good I just got mine!
Re: 440 Source Stealth aluminum heads - any good? [Re: maximus] #61409
05/22/08 06:44 PM
05/22/08 06:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Surprised to hear that, considering when dwayne(fast68plymouth) flow tested both stealths and e-heads(straight out of the box), the stealth and RPM's flowed within 5% of each other at all lifts. So unless those eddy's were victors, I find a 40hp difference(with no other tuning changes) hard to believe unless something was defective on one of the stealth heads.
Re: 440 Source Stealth aluminum heads - any good? [Re: Thor500] #61410
05/23/08 08:54 AM
05/23/08 08:54 AM
massachusetts
ct71rr Offline
ct71rr  Offline
massachusetts
Me too
Re: 440 Source Stealth aluminum heads - any good? [Re: JohnRR] #61411
08/03/08 11:07 PM
08/03/08 11:07 PM
NE, USA
1stwing Offline
1stwing  Offline
NE, USA
still waiting for an answer on what people think of these heads since they have now been out for several months.
Re: 440 Source Stealth aluminum heads - any good? [Re: 1stwing] #61412
08/03/08 11:19 PM
08/03/08 11:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have not used them and in fact I have 906 iron heads on my 63 but from what I have heard they are a great deal for the price. They are just about the same as the Eddy heads and should work good on a motor up to 600 hp with some work. They are definetly better then 40 year old factory iron heads. I would not hesitate to use them on a nice bigblock build for a street car as you cant beat the price. Ron
Re: 440 Source Stealth aluminum heads - any good? [Re: 383man] #61413
08/03/08 11:30 PM
08/03/08 11:30 PM
Manitoba, Canada
Manitoba, Canada
I think they're a case of 'good news is no news'.
Re: 440 Source Stealth aluminum heads - any good? [Re: KAHUDA] #61414
08/03/08 11:51 PM
08/03/08 11:51 PM
AndyF Offline
AndyF  Offline
Buy the CNC version. Upgrade the locks and retainers and you should be ready to make some pretty good power.
Re: 440 Source Stealth aluminum heads - any good? [Re: KAHUDA] #61415
08/03/08 11:54 PM
08/03/08 11:54 PM
iowa
copchaser Offline
copchaser  Offline
iowa
Stock wise they aren't much better than factory heads, but they respond very well to porting. My guy that does my porting is getting 326 out of them. So I say stock for stock go with the Edelbrocks, but if a full port job is planed save a few bucks and by the stealths.
Re: 440 Source Stealth aluminum heads - any good? [Re: copchaser] #61416
08/04/08 12:11 AM
08/04/08 12:11 AM
Manitoba, Canada
Manitoba, Canada
Huh? I have to ask why you think this? Considering when dwayne flow tested them, he found OOTB stealths to flow +/- 5% of OOTB eddy rpms at all lifts. So if they flow the same as e-heads, why would they be no better than factory heads in stock form?
Re: 440 Source Stealth aluminum heads - any good? [Re: DaytonaTurbo] #61417
08/04/08 12:57 AM
08/04/08 12:57 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
G-bob has a set for the wifes car seem to be as good as RPMs OOTB
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 440 Source Stealth aluminum heads - any good? [Re: R70RUNNER] #61418
08/04/08 01:02 AM
08/04/08 01:02 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i am happy with mine, i upgraded locks and retainers and no complaints at all
Re: 440 Source Stealth aluminum heads - any good? [Re: chrisf] #61419
08/04/08 06:29 AM
08/04/08 06:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine are working fine also.Been on for 3 months.I also upgraded to dual springs and locks and retainers.My machinist also back cut the valves because he is a perfectionest.They will get ported in the future.Rocky
Chrysler Firepower
Re: 440 Source Stealth aluminum heads - any good? [Re: AndyF] #61420
08/04/08 09:50 AM
08/04/08 09:50 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Are the CNC heads from 440source or an aftermarket guy?
Re: 440 Source Stealth aluminum heads - any good? [Re: bobby66] #61421
08/04/08 10:42 AM
08/04/08 10:42 AM
AndyF Offline
AndyF  Offline
440Source has the CNC heads on their website. You could also send the heads to Modern Cylinder Head in MI for the porting if you already have the heads.
Re: 440 Source Stealth aluminum heads - any good? [Re: AndyF] #61422
08/04/08 11:29 AM
08/04/08 11:29 AM
NH
Fastback67 Offline
Fastback67  Offline
NH
Myself, I have found that like any other head you by, they normally require a good valve job and that's about it. Maybe an upgrade to 10 degree locks & keepers. Mine are in the shop right now, but here are a few comments from a friend of mine...
I did a good 3 angle valve job on the intake side , a 32deg back cut on the valve & blended the chamber. picked up 10 cfm from .200 -.700 lift with no other port work. the exhaust has a 30deg top cut, and a 45 seat with a radius.picked up 8-10 cfm from 200-500 lift & 16 cfm at 700 lift.just blended the valve job & chamber.I dont want to sound like im busting 440 source's chops,im still pleased with these heads,but another problem I found was the seats were not driven all the way down. they were about .010 to high. I plan on hogging these things out this weekend & reflowing them monday.
Here are my flow #'s for my stealt heads.I didn't try to port these things to the max,because it defeats the reason for buying these heads in the first place.For the money spent vs flow potential, I think they are a good deal. I also compared these #'s to the mopar performance aluminum head and the stealths flow better.
.100-82 .100-81
.200-178 .200-147
.300-231 .300-169
.400-274 .400-194
.500-292 .500-211
.600-300 .600-224
.700-301 .700-231
I used a 4.500 stand [its the smallest we've got]so the #'s will be down a little if you use the correct bore for your application.We use a 1020 bench which is alot more accurate than a 600 bench, also the 600 bench will read higher flow #'s on the int side than the 1020.
