drive train vibration.HELP #613694
02/14/10 10:41 PM
02/14/10 10:41 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
I have a bad drive train vibration from about 2800 rpm up..Heres what i've done..it's a 440 with t-flight,8 3/4rear..motor is smooth in neutral. I have 2 converters.stock and 3000 stall.no change..stock drive shaft,and 3 + inch shaft custom made and both balanced as I had to have them stortened for my install.I have 2 center sections for the rear, one has 3:91 gear the other 2:76 open for road trips..that was the original 741 chunk that came with the rear housing, the other is a 489 with posi.Vibration with any combo is at 2800,tires balanced a few times plus another set,plus the Hoosiers.I'm out of things to try..feels like drive shaft type of vibration.I have gone from down 2 dg to o dg to up 2 dg on the pinion angle.Any ideas ???PLEASE READ MY LAST POST FOR THE RESULTS ..VIBRATION IS ALMOST GONE,THANKS EVERYONE FOR YOUR HELP.
Re: drive train vibration.HELP [Re: dynamite] #613695
02/14/10 10:46 PM
02/14/10 10:46 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
How is pinion angle ?
Re: drive train vibration.HELP [Re: OzHemi] #613696
02/14/10 10:48 PM
02/14/10 10:48 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Oh, you must have added that bit..
Re: drive train vibration.HELP [Re: OzHemi] #613697
02/14/10 10:49 PM
02/14/10 10:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Read his Original post.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: drive train vibration.HELP [Re: MoparforLife] #613698
02/14/10 10:53 PM
02/14/10 10:53 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
Is the exhaust mounted ridged or with good rubber hangers? Is it hitting anywhere?
Re: drive train vibration.HELP [Re: 1hot68] #613699
02/14/10 10:59 PM
02/14/10 10:59 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
tail shaft bushing?
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: drive train vibration.HELP [Re: 1hot68] #613700
02/14/10 11:01 PM
02/14/10 11:01 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Sorry OZ did edit that in.. with exhaust or just the headers ,,still there
Re: drive train vibration.HELP [Re: 1hot68] #613701
02/14/10 11:02 PM
02/14/10 11:02 PM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
Possibly a bad bushing in tail shaft?
Re: drive train vibration.HELP [Re: FurryStump] #613702
02/14/10 11:03 PM
02/14/10 11:03 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
engine mounts arent sagging? The headrs have any contact with the block? even just a little contact will be felt in a unibody car. What car is it?
Re: drive train vibration.HELP [Re: 1hot68] #613703
02/14/10 11:09 PM
02/14/10 11:09 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
cracks in the flywheel?
Re: drive train vibration.HELP [Re: dynamite] #613704
02/14/10 11:10 PM
02/14/10 11:10 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Many things can cause a driveline vibration:
Too much downward pinion angle will cause a vibration on deceleration.
Too much upward pinion angle will cause a vibration on acceleration.
Driveshaft run out
More than 1" slip yoke (internal) stand out
Less than 3/4" slip yoke (internal) stand out
Sloppy fitting slip yoke bushing
Sloppy fitting slip yoke splines
Sloppy fitting U-joint saddles/missing clips
Solid motor mounts
Poly transmission mount
Loose pinion yoke
Engine/bellhousing alignment
Torque converter/vibration damper balance
Exhaust grounding out on body
etc...
Re: drive train vibration.HELP [Re: 1hot68] #613705
02/14/10 11:11 PM
02/14/10 11:11 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Not an exhaust problem..headers don't touch anything..vibration is there with the rest of the exhaust system off,for a 1/4 mile run..and yes it runs faster with the exhaust on.Car is my 1956 Plymouth you have seen here a lot.
Re: drive train vibration.HELP [Re: MoparforLife] #613706
02/14/10 11:11 PM
02/14/10 11:11 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
He changed it, was not there originally...that is the first thing that came to mind with his going over other issues he has checked on..
Re: drive train vibration.HELP [Re: OzHemi] #613707
02/14/10 11:16 PM
02/14/10 11:16 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
DR Diff ...the vibration is there at a constant speed.. not only on accel or decell.just crusing at a steady 3000 rpm or so.
Re: drive train vibration.HELP [Re: dynamite] #613708
02/14/10 11:20 PM
02/14/10 11:20 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Does it change if you put the car in nuetral at that speed ?
Maybe it's an issue in the engine or trans ? (if it does it at 3000 rpm in any gear lets say)
Re: drive train vibration.HELP [Re: dynamite] #613709
02/14/10 11:22 PM
02/14/10 11:22 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
What angle is your pinion centerline at rest?
What angle is your transmission centerline at rest?
These angles should be a couple degrees within parallel.
Re: drive train vibration.HELP [Re: DoctorDiff] #613710
02/14/10 11:31 PM
02/14/10 11:31 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
DR diff..righr now it is as close to zero as I can get it..Drive shaft when first made for me was a hair too long and was hard to get in, but once past the yolk it still had about a half inch play..I took it back and had it shortened another 3/4 inch..it had the vibration both ways..no change
Re: drive train vibration.HELP [Re: dynamite] #613711
02/14/10 11:35 PM
02/14/10 11:35 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
OZ HEMI.. yes the vibration is there if I put it into neutral at that speed..trans bushing thing may be my next thing to check..Thanks Jeff
Re: drive train vibration.HELP [Re: dynamite] #613712
02/14/10 11:46 PM
02/14/10 11:46 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Be interesting to get the car on a chassis dyno so you could look under it at speed and see if you can see anything moving, feel for vibration at different points,etc...
Aside from what Cass said about angles...are the u-joints in good shape too ?
Cracked flexplate maybe on a long shot ?
Re: drive train vibration.HELP [Re: dynamite] #613713
02/15/10 02:24 AM
02/15/10 02:24 AM
Not moving it is smooth @ 2800 in neutral right? I gotta go w driveshaft related as you originally mentioned. ujoint/shaft/yoke/angles
