drive train vibration.HELP
#613694
02/14/10 10:41 PM
02/14/10 10:41 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
I have a bad drive train vibration from about 2800 rpm up..Heres what i've done..it's a 440 with t-flight,8 3/4rear..motor is smooth in neutral. I have 2 converters.stock and 3000 stall.no change..stock drive shaft,and 3 + inch shaft custom made and both balanced as I had to have them stortened for my install.I have 2 center sections for the rear, one has 3:91 gear the other 2:76 open for road trips..that was the original 741 chunk that came with the rear housing, the other is a 489 with posi.Vibration with any combo is at 2800,tires balanced a few times plus another set,plus the Hoosiers.I'm out of things to try..feels like drive shaft type of vibration.I have gone from down 2 dg to o dg to up 2 dg on the pinion angle.Any ideas ???PLEASE READ MY LAST POST FOR THE RESULTS ..VIBRATION IS ALMOST GONE,THANKS EVERYONE FOR YOUR HELP.
Re: drive train vibration.HELP
[Re: dynamite]
#613704
02/14/10 11:10 PM
02/14/10 11:10 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
Many things can cause a driveline vibration:
Too much downward pinion angle will cause a vibration on deceleration.
Too much upward pinion angle will cause a vibration on acceleration.
Driveshaft run out
More than 1" slip yoke (internal) stand out
Less than 3/4" slip yoke (internal) stand out
Sloppy fitting slip yoke bushing
Sloppy fitting slip yoke splines
Sloppy fitting U-joint saddles/missing clips
Solid motor mounts
Poly transmission mount
Loose pinion yoke
Engine/bellhousing alignment
Torque converter/vibration damper balance
Exhaust grounding out on body
etc...
[Re: MoparforLife]
#613706
02/14/10 11:11 PM
02/14/10 11:11 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
How is pinion angle ?
Read his Original post.
He changed it, was not there originally...that is the first thing that came to mind with his going over other issues he has checked on..
[Re: dynamite]
#613712
02/14/10 11:46 PM
02/14/10 11:46 PM
OzHemi
Garden Grove, CA
Be interesting to get the car on a chassis dyno so you could look under it at speed and see if you can see anything moving, feel for vibration at different points,etc... Aside from what Cass said about angles...are the u-joints in good shape too ? Cracked flexplate maybe on a long shot ?
