Truck 440/727 and dana 60.. can I use it in my B-body? #613678
02/14/10 10:12 PM
02/14/10 10:12 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Looking for a donor motor for my 69 Coronet. I found a 78 Dodge truck with a strong 440/727 and Dana 60 rear with 3:55 gears. I know the motor will drop in, but what about the trans and rearend? Probably a dumb question..but one I don't know the answer too...
Re: Truck 440/727 and dana 60.. can I use it in my B-body? [Re: dssaa] #613679
02/14/10 10:15 PM
02/14/10 10:15 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Trans should as long as it's not a short tail or 4x4. The rear would probably need narowed.
Re: Truck 440/727 and dana 60.. can I use it in my B-body? [Re: dssaa] #613680
02/14/10 10:27 PM
02/14/10 10:27 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Narrow the rear and make it 5 lug of course, and don't forget you'll need a car oil pan for the engine too.
Re: Truck 440/727 and dana 60.. can I use it in my B-body? [Re: dssaa] #613681
02/14/10 10:38 PM
02/14/10 10:38 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
If the truck is in great condition you may want to think twice about parting it out. YOu may make enough money on reselling it to go towards even more cool stuff.
Re: Truck 440/727 and dana 60.. can I use it in my B-body? [Re: Blakcharger440] #613682
02/14/10 10:43 PM
02/14/10 10:43 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
What ton is the truck?
If it's a half ton, then the trans will work, but the "dana" will be a 9.25 mopar not a dana 60
If it's a 3/4 ton the 727 will likely be a short shaft version, and the d 60 will need to have flange ends welded on, axles etc..
If it's a dually, the 727 is as above. The dana will probably be a d70, not a d 60, and not worth narrowing.
Re: Truck 440/727 and dana 60.. can I use it in my B-body? [Re: dave571] #613683
02/15/10 12:10 AM
02/15/10 12:10 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Truck is a 3/4 ton. Claims to be rust free and in great shape, but I don't need a truck, just a motor to put the Coronet back in action. Not sure there is much of a market for 3/4 ton truck parts around here.
Re: Truck 440/727 and dana 60.. can I use it in my B-body? [Re: dssaa] #613684
02/15/10 12:40 AM
02/15/10 12:40 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Nice boxes are usually easy to sell.
Guys who restore LRTs seem to appreciate mint '78 grilles/radiator supports/front clips. Every time I take that stuff to the Mopar Nationals, it sells quickly.
