more dominator questions #613038
02/14/10 09:26 AM
02/14/10 09:26 AM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
found a practically new alcohol dominator reasonable and was told the jets and air bleeds had been changed to run e-85 is this possible and can it be run with no issues or should it be put back on alcohol. this is a holley carb not a custom from a carb shop
Re: more dominator questions [Re: dbran451] #613039
02/14/10 09:52 AM
02/14/10 09:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure it possible... my 8896 is set up for E-85.. was
a gas dom.... if your talking running alky then yes
it should have the bleeds and jets set up for the alky
other wise you would be lean
Re: more dominator questions [Re: dbran451] #613040
02/14/10 10:15 AM
02/14/10 10:15 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Are you going to run alcohol or e-85?
If it is a stock alcohol dominator and you are going to run alcohol go on Holley website and the out of box jetting will be there. It is a little tricky to find but it is there. All you need is the model number. I have always found this is a very good place to start.
Re: more dominator questions [Re: mac56] #613041
02/14/10 10:47 AM
02/14/10 10:47 AM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
the carb was re jetted and air bleeds changed for e-85 i am leaning toward the e-85.
Re: more dominator questions [Re: dbran451] #613042
02/14/10 12:00 PM
02/14/10 12:00 PM
NC
440Jim Offline
440Jim  Offline
NC
If you want to run E85, I would change the boosters also. The main wells and metering block passages will be too big for E85, but it could be tweaked to run OK. The idle circuit and emulsion circuit could be wrong also.
