custom-arched brake shoe,s #611825
02/12/10 08:46 PM
02/12/10 08:46 PM
highland co ohio
buckeye Offline OP
buckeye  Offline OP
highland co ohio
hi just read an article in hemmings muscle about a a-12 super bee they talked about custum -arch brake shoes on 11 inc drum,s anyone have these or any imformation on them thank,s as usal
Re: custom-arched brake shoe,s [Re: buckeye] #611826
02/12/10 09:13 PM
02/12/10 09:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There was a post on this a few days ago so a quick search might find it.
Re: custom-arched brake shoe,s [Re: buckeye] #611827
02/12/10 09:14 PM
02/12/10 09:14 PM
You would call your brake specialty shop & inquire if (1) they have the equipment to arc them (2) if they need the drums to measure them exactly (I would imagine so) (3) If any restriction on the kind of lining they can or cannot grind then you would take your drums and shoe purchase in to them. Might ask them on their recommendation for performance shoes also.
Re: custom-arched brake shoe,s [Re: buckeye] #611828
02/12/10 09:20 PM
02/12/10 09:20 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Wayne Smothers, the guy who worked on the car and had the brakes done, is a member here.
Big Squeeze
Earning every penny of that moderator paycheck.
DBAP
Re: custom-arched brake shoe,s [Re: not_a_charger] #611829
02/12/10 10:01 PM
02/12/10 10:01 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
By performing this proceedure,it insures that the max amount of shoe hits the drum.Have you ever seen shoes where it looks like just the outer part of the shoe is wearing and the center is untouched??This helps eliminate this condition
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: custom-arched brake shoe,s [Re: buckeye] #611830
02/12/10 11:31 PM
02/12/10 11:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The metal shoes aren't arched, the material is ground (or "arched") to match the drums. The shop manual calls for this too.
Years ago I took a set back to a shop and explained what "needed" to be done. They looked at me kinda funny but took all the stuff. The next day I got them back and someone had had at them with a disk grinder. I used them and they worked but given the amount of work the rears do I think its a waste on anything but a track car of sorts - and then they likely wouldn't be using drums! I think they'd wear in pretty quick anyhow.
Re: custom-arched brake shoe,s [Re: buckeye] #611831
02/13/10 08:31 PM
02/13/10 08:31 PM
highland co ohio
buckeye Offline OP
buckeye  Offline OP
highland co ohio
was wondering just how good the stoping power was and if any one had them installed
