Page 4 of 4 1 2 3 4
Re: Year One Fuel Tank [Re: DodgeMaterial] #61163
05/26/08 06:17 PM
05/26/08 06:17 PM
St. Louis, MO
DodgeMaterial Offline
St. Louis, MO
Here is a pic - not fully installed in this pic - but hopefully you can get the idea of its appearance. Dave
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: Year One Fuel Tank [Re: DodgeMaterial] #61164
05/26/08 06:34 PM
05/26/08 06:34 PM
St. Louis, MO
St. Louis, MO
Another shot - closer-up. Dave
Re: Year One Fuel Tank [Re: 70 buzz] #61165
05/27/08 11:19 AM
05/27/08 11:19 AM
Kelowna, B.C. Canada
DPelletier Offline OP
I wonder if the Ni-terne plated is what makes the tank appear to be painted silver
Not on the two that I have; they are clearly painted silver. You can see in the pics that the spot welds and pinch welds are painted as are the rubber ECS plugs! Night and day compared to the Charger tank.
ps. I haven't forgotten about the hood, but I had a dinner right after work and didn't get home 'till 10:00 last night. I'll try to get some pics for you after work today.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Year One Fuel Tank [Re: DodgeMaterial] #61166
05/27/08 11:23 AM
05/27/08 11:23 AM
That one looks good. It makes you wonder about the seam, 'cause the two that were correct in this thread both had the overlapped pinchwelds rather than the radius ones.......
Re: Year One Fuel Tank [Re: DPelletier] #61167
05/27/08 04:46 PM
05/27/08 04:46 PM
Alright: UPDATE
I just recieved tank #4. It IS the right tank AND it has the correct finish. Only minor problems are the ECS nipples and some bending of the flanges at the corners.
So I finally have a tank that is satisfactory that I can use. Yes, it did cost me $685.00
This latest tank is IDENTICAL in all construction details to the CR9A tank sent previously (excepting the Charger filler location obviously).
I believe that ALL FOUR tanks were made by Spectra Premium;
- they all have a Made In Canada sticker
- They all have similar/identical part numbers
- the accessory grommets are all stamped "Made In Canada" and all have the same LO06 part number.
It would appear to me that they have two lines: a budget one and a more correct one. The budget line is characterized by the painted finish, raised numbers stamped into the top and the radius corner welds. The more correct one is raw metal/galvanized finish, has the square, overlapping corner welds and has the identifying information on a sticker with no stamped numbers on the tank.
........only problem is that these two are being used interchangeably. They probably don't think most people care.
Re: Year One Fuel Tank [Re: DPelletier] #61168
05/27/08 05:22 PM
05/27/08 05:22 PM
BC
70RT27N Offline
70RT27N  Offline
BC
Hopefully someone else can learn from your nightmare. The hobby is hard enough without
having to put up with this crap from vendors.
Re: Year One Fuel Tank [Re: DPelletier] #61169
05/27/08 08:57 PM
05/27/08 08:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
my guess is perhaps the two different manufacturing techniques are a result of being made in different locations.
Re: Year One Fuel Tank [Re: DPelletier] #61170
05/28/08 09:43 AM
05/28/08 09:43 AM
Central,AR
hemi_tyme Offline
hemi_tyme  Offline
Central,AR
OK guys, pics as promised;
1st tank from YO;
Note painted finish, ECS nipples (I assume)
Dave, those are vent nipples. ECS would also include 4 more nipples on the flat area on the right side of the picture.
Ken
Re: Year One Fuel Tank [Re: fast68plymouth] #61171
05/28/08 10:51 AM
05/28/08 10:51 AM
Perhaps, or maybe there was a change in the manufacturing process and one type is newer than the other.
Re: Year One Fuel Tank [Re: hemi_tyme] #61172
05/28/08 10:53 AM
05/28/08 10:53 AM
1st tank from YO;
Ken
Thanks Ken!
I was hoping someone could confirm what those nipples were for. That's great news. One puzzling thing is that the Charger tank ( CR9A ) didn't have the nipples.
Re: Year One Fuel Tank [Re: DPelletier] #61173
05/28/08 07:03 PM
05/28/08 07:03 PM
Anderson, SC
resqguy Offline
resqguy  Offline
Anderson, SC
I don't mean to hijack, but if a car has a functional, original, non-leaking tank should they be replaced?
Re: Year One Fuel Tank [Re: resqguy] #61174
05/28/08 07:34 PM
05/28/08 07:34 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Technically, no...but....
More often than not the appearance looks crappy, even if the integrity of the tank is sound. In the case of a car like Dave's, which is an "all out" rotisserie restoration, then a weathered, dented, original tank just isn't appropriate.
MB
Re: Year One Fuel Tank [Re: HPMike] #61175
05/29/08 11:30 AM
05/29/08 11:30 AM
MB
In my case, not only was the tank dented and weathered, it also was severely rusty inside (I was actually able to pour out a quantity of scale!). With all new fuel lines, pump, carbs, etc. I wanted to ensure that the entire fuel system was new and clean.
Re: Year One Fuel Tank [Re: DPelletier] #61176
05/30/08 09:21 PM
05/30/08 09:21 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
1st tank from YO;
Ken
Thanks Ken!
Yup, those are the nipples for the tanks vents.
Page 4 of 4 1 2 3 4
