Pick My Cam & Intake! #611029
02/12/10 12:16 AM
02/12/10 12:16 AM
Salinas, CA USA!
BuBbABFP Offline OP
BuBbABFP  Offline OP
Salinas, CA USA!
Hello fellow Mopar friends! My name is Roy(23) and I am in the process of getting my 68 Charger all freshened up. My car is an original 318 and I just recently purchased a 440 witch was rebuilt.(possible standard bore and compression) well the previous owner said that the guy who had it may have put a cam in it but I don't know. I bought the engine COMPLETE came with eddy 1411 750 and eddy performer 440 non RPM.
block numbers are 4006630-440-10, the heads are 516's and have less than 100 miles on a fresh rebuilt, but I will not be using these heads i have purchased some (0 miles) 906's(2843906) with the following modifications: Ports and pockets ported out full length, multi angle valve job blended stock 2.08 intake and ex 1.74 valves reground hard seat, seals replaced, new hp springs good to .575 lift, 130 psi seat press 330 at .500, lift deck milled .020 open chamber 82 cc.
Now I want a cam that will take advantage of the heads at that max lift, I have a rebuilt 727(3k converter), car will have 3.55 gears in the 8 3/4. as for carburetor, I will be going with the new FAST EZ EFI KIT i was thinking of going with a Edelbrock Torker II.
Thanks guys, I would appreciate the help! =)
1968 Dodge Charger
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611030
02/12/10 01:53 AM
02/12/10 01:53 AM
Welcome here Roy. When I read EFI that where my knowledge ends .
Re: Pick My Cam & Intake! [Re: RapidRobert] #611031
02/12/10 09:43 AM
02/12/10 09:43 AM
scratchnfotraction Offline
welcome to the board Roy
the info is here,I just dont have it
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611032
02/12/10 10:38 AM
02/12/10 10:38 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Don't waste your money on EFI. as far as cams go it depends on your skill level. A nice solid with roller rockers will really wake that engine up, however you could just take the easy route and buy the 513/533 VooDoo cam. I'd try and find a dual plane intake to use, RPM would be best but hood clearance is an issue. Holley S/D or old Eddy CH4B w/ a 4 hole spcer would be good too. I take that 750 Eddy straight to e-bay and get what you can for it. Then go buy a holley 750DP. You should be ready to roll then. Good luck and welcome
Coming soon!!!!
Re: Pick My Cam & Intake! [Re: Mr.Yuck] #611033
02/12/10 11:33 AM
02/12/10 11:33 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd go eddie RPM, and comp XE275HL for a cam I think....
if you're willing to spend the money for the FAST system, I'd consider maybe dropping to an eddie 800 thunder series carb and spend the $$ on a retrofit hydraulic roller cam setup...
2017 Grand Cherokee Overland
Re: Pick My Cam & Intake! [Re: patrick] #611034
02/12/10 11:36 AM
02/12/10 11:36 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
When you yank the heads, measure how far down in the hole the pistons are. Either report back with that info, or figure your compression yourself. Your calculated compression or lack thereof, will determine cam selection.
Id verify that the 906s are 82CC, that seems a little small with a stock valve, and only a .020 cut.
Do you have flow sheets on the heads? You say you want to maximize the cam at .575 lift. Unless the heads were done by somebody who knows what they are doing most likely they wont flow much more air at .575 vs. .500. No need to go with more lift if you dont need it. Id have em flowed and see what the flow curves look like.
A Torker II would be my last choice, as mentioned either a RPM or Street Dominator.
Id also skip the EFI. As mentioned a 750-800 DP. With the money you saved from not going EFI, get a good AFR meter and get the tune on.
FWIW, a few years back I had a basic street 440 with stock converter, 3.23s in a 3800 lb car. I had a CH4B on it, went to a M1 and picked up 3 MPH. I also had a Erson 228/.476 cam in it and for such a mild cam it ran pretty decent.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611035
02/12/10 12:07 PM
02/12/10 12:07 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Well, If you do go with the FAST EZ-EFI Choose the Eddy EFI manifold for port injection (# 29545) and get the fuel rail kit too (# 3640). You can order the manifold with the fuel rails (# 29546). Then buy the EZ kit for port injection. The EZ for Port injection works better than the throttle body type.
As far as the cam goes, I'd run a nice solid flat tappet. The only change for EFI would be to increase the LSA (lobe separation angle) to 112 - 114. I'd stay in the 235 @ .050 for the intake duration and 240 @ .050 for the exhaust with with just over .500 lift. This would be very close to the Comp XE274S (236/242) only with the LSA changed. You'd end up with a nice high torque street motor.
Re: Pick My Cam & Intake! [Re: Mopar_Rich] #611036
02/12/10 11:00 PM
02/12/10 11:00 PM
Salinas, CA USA!
BuBbABFP Offline OP
BuBbABFP  Offline OP
Salinas, CA USA!
Hey guys, thanks very much for the much needed info, bare with me I am learning as we go. I was thinking about ditching the EFI and I think I will, I will get a nice DP BG or Holley when I decide what combo I will be going. Now I have another dilemma.. I keep on hearing that my block is crap and has crap compression compared to the older 440's but then again I see on here that even the older 440's are low in compression and just look better on paper? what do ya'll say about that?
So now I am worried that I may have very low compression and will not be able to take advantage of the heads and cam combo you guys are trying to set me up with, they told me to go an measure on how deep the pistons are in the hole to give me an Idea on what CR it has..but yet I have no clue on how to do that.. some good direction on how to do that would be appreciated.. Another thing the previous owner said it was rebuilt, if indeed i have super low compression, can I just buy a new set of forged pistons and rods and just bolt em up to help me raise compression to make great power and still use 91 pump gas? without need of taking to machine shop..I have buddies that can help me with piston/rod installation and are knowledgeable,, motor was running 1 year ago and maybe has few thousand miles on rebuilt.., btw I hand crank the motor with no plugs and it spins smooth but takes some force, motor has oil..
Thanks all, Roy Oh the new 906 head will have hardened seats.
1968 Dodge Charger
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611037
02/12/10 11:37 PM
02/12/10 11:37 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You're too young to have a '68 Charger
You should hand it over to me
If the pistons and rods look good then I'd just deck the block to get your compression where you want it. Don't forget to pick a head gasket first.
Love those cars, sounds like everyone's got you covered Good Luck
Re: Pick My Cam & Intake! [Re: roadhazard] #611038
02/13/10 12:20 AM
02/13/10 12:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Good advice hear for you. But I would check the head cc's as Von said. I can tell you I run 906 heads that are cut .060 and they cc'd out to 76 cc's. Good luck with it. Ron
Re: Pick My Cam & Intake! [Re: roadhazard] #611039
02/13/10 01:08 AM
02/13/10 01:08 AM
Salinas, CA USA!
BuBbABFP Offline OP
BuBbABFP  Offline OP
Salinas, CA USA!
Yeah, when I tell people that I have a 68 Charger they really get surprised..especially older Mopar guys!
As for the heads the 82cc is what is claimed..he is actually shipping them to me on Tuesday because he is installing harden seats. I will flow bench them when I receive them.
Any of yah have a saying on my last post #5800653?
thanks, Roy.
1968 Dodge Charger
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611040
02/13/10 01:10 AM
02/13/10 01:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As for the heads the 82cc is that is claimed..he is actually shipping them to me on Tuesday because he is installing harden seat. I will flow bench them when I receive them.
thanks, Roy.
Good deal. Ron
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611041
02/13/10 01:43 AM
02/13/10 01:43 AM
San Antonio, TX
CurYellowBird Offline
San Antonio, TX
Young mopar guys are taking over O wait I can't show that smile cause I'm underage lol. I got a buddy in the local mopar club that is running a 69' charger RT and he's 22.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Pick My Cam & Intake! [Re: CurYellowBird] #611042
02/13/10 11:28 PM
02/13/10 11:28 PM
Salinas, CA USA!
BuBbABFP Offline OP
BuBbABFP  Offline OP
Salinas, CA USA!
Young Mopar guys FTW! hehe
1968 Dodge Charger
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611043
02/14/10 12:49 PM
02/14/10 12:49 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
thanks, Roy.
Just out of curiosity if you have already paid for the set of 906 heads did you end up spending more on them than a set of aluminum Edelbrock RPM's?
Re: Pick My Cam & Intake! [Re: Blakcharger440] #611044
02/14/10 03:41 PM
02/14/10 03:41 PM
Salinas, CA USA!
BuBbABFP Offline OP
BuBbABFP  Offline OP
Salinas, CA USA!
thanks, Roy.
No, I paid about 530$ for them. I thought it was a good deal.
1968 Dodge Charger
Re: Pick My Cam & Intake! [Re: BuBbABFP] #611045
02/14/10 04:14 PM
02/14/10 04:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You are going to have to pull a cylinder head to measure your compression before you decide on a cam. For intake, performer rpm and a drop-base air cleaner if it'll work for ya. If not then I'd be looking at a holley street dominator.
