727 END PLAY #610883
02/11/10 09:02 PM
02/11/10 09:02 PM
Texas
redram95 Offline OP
redram95  Offline OP
Texas
Did not check end play before tear down. After rebuild I have .096 end play with both the .102 shims installed. Any ideas?
Re: 727 END PLAY [Re: redram95] #610884
02/11/10 09:06 PM
02/11/10 09:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What year?
Re: 727 END PLAY [Re: John_Kunkel] #610885
02/11/10 09:09 PM
02/11/10 09:09 PM
Texas
redram95 Offline OP
redram95  Offline OP
Texas
1987 3 speed non lock-up
Re: 727 END PLAY [Re: redram95] #610886
02/11/10 09:21 PM
02/11/10 09:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are there two thrust washers on the output shaft? Sometinmes the thin steel washer goes missing and the 3-eared washer by itself won't provide enough thickness.
Re: 727 END PLAY [Re: John_Kunkel] #610887
02/11/10 09:27 PM
02/11/10 09:27 PM
Texas
redram95 Offline OP
redram95  Offline OP
Texas
I have the three tab washer and the shim,
Re: 727 END PLAY [Re: redram95] #610888
02/12/10 12:29 AM
02/12/10 12:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
is that the play in the output shaft or the input shaft?
