67 Hemi Fan Spacer #610870
02/11/10 09:01 PM
02/11/10 09:01 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Trying to mount the fan on a 67 Hemi engine. I have a spacer #1730155 that measures 1.060 thick. The 67 Chrysler parts book shows a part number 1851959. I don't know how thick this one is? I have a amk products #66-E74 engine bolt kit that says it is for the 66-67 engines. The fan bolt in it says it is to be used with a 1.24 inch spacer.
If I look at some web sites that shows the bolts for use with the 1851959 spacer, they say it is 1.060 thick? I'm
What is the correct spacer number and thickness I should be using, and are the correct bolts offered for this.
Dan
Re: 67 Hemi Fan Spacer [Re: mopar4ya] #610871
02/12/10 07:40 PM
02/12/10 07:40 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Dan
Re: 67 Hemi Fan Spacer [Re: mopar4ya] #610872
02/12/10 11:25 PM
02/12/10 11:25 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Dan,
I'll check mine tomorrow and let you know plus here's a
Tom
68 Charger
70 Cuda
Re: 67 Hemi Fan Spacer [Re: FC7cuda] #610873
02/13/10 12:51 AM
02/13/10 12:51 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
According to the 67 Parts Book, the 1851959 spacer is for B & C-Body 383, 440 & 426 without A/C. It was also used on the 67 A-Bodies with /6 and no A/C.
Re: 67 Hemi Fan Spacer [Re: mopar4ya] #610874
02/13/10 12:52 AM
02/13/10 12:52 AM
BFE
blue67440's Offline
blue67440's  Offline
BFE
If your car is an auto and utilizes the 4 blade "34" fan then i'm pretty sure you need a 18259 32 spacer that is 1.24" thick.
If you find that's what you need I think I have a few good spares and I'll send you one.
blue
XP29L72 A833 in 881 XP29L72 A727 in 881
Re: 67 Hemi Fan Spacer [Re: blue67440's] #610875
02/13/10 10:59 AM
02/13/10 10:59 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
The car is a 4 speed. The spacer and fan I have came off of a 66 Hemi automatic. I thought they would have been the same??? maybe not. I don't have a 66 parts book. Could someone that has a book look them up?
Dan
Re: 67 Hemi Fan Spacer [Re: mopar4ya] #610876
02/13/10 02:28 PM
02/13/10 02:28 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
If you have a buildsheet it will tell you the last 2 #'s of the part # of the spacer you need. Look at the casting # under the spacer and find a match.
Re: 67 Hemi Fan Spacer [Re: mopar4ya] #610877
02/13/10 02:31 PM
02/13/10 02:31 PM
Snoopy Offline
Snoopy  Offline
66 Part Book
1851959 w/o a/c all transmissions
Re: 67 Hemi Fan Spacer [Re: hemi70se] #610878
02/13/10 04:47 PM
02/13/10 04:47 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Why didn't I think of that , Thanks!
Dan
Re: 67 Hemi Fan Spacer [Re: mopar4ya] #610879
02/13/10 07:41 PM
02/13/10 07:41 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I used to have a 67 Hemi R/T that had a build date of Nov 16. I checked the copy I have of the buildsheet on that and it has a #32 fan spacer code. Fan code is #34 BTW (4 blade). Now just find a spacer with a part #xxxxx32 cast in the bottom.
Re: 67 Hemi Fan Spacer [Re: hemi70se] #610880
02/13/10 08:28 PM
02/13/10 08:28 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've got a '67 Hemi GTX with a January 15 build date. Same thing, '34' fan and '32' spacer.
Re: 67 Hemi Fan Spacer [Re: 6PakBee] #610881
02/13/10 10:31 PM
02/13/10 10:31 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
"32" spacer is part #1825932 which is 1.24" long
Re: 67 Hemi Fan Spacer [Re: twodoorpost] #610882
02/14/10 08:15 AM
02/14/10 08:15 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Ok, I looked on my broadcast sheet, and sure enough it has the #32 on it. So the 1825932 spacer is what I need. Was lucky enough to have one here .
Thanks!
Dan
