67 Hemi Fan Spacer
#610870
02/11/10 09:01 PM
02/11/10 09:01 PM
Posts: 2,655 western PA
mopar4ya
western PA
Trying to mount the fan on a 67 Hemi engine. I have a spacer #1730155 that measures 1.060 thick. The 67 Chrysler parts book shows a part number 1851959. I don't know how thick this one is? I have a amk products #66-E74 engine bolt kit that says it is for the 66-67 engines. The fan bolt in it says it is to be used with a 1.24 inch spacer. If I look at some web sites that shows the bolts for use with the 1851959 spacer, they say it is 1.060 thick? I'm What is the correct spacer number and thickness I should be using, and are the correct bolts offered for this. Thanks Dan
Re: 67 Hemi Fan Spacer
[Re: mopar4ya]
#610872
02/12/10 11:25 PM
02/12/10 11:25 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Dan, I'll check mine tomorrow and let you know plus here's a Tom
68 Charger 70 Cuda
[Re: mopar4ya]
#610874
02/13/10 12:52 AM
02/13/10 12:52 AM
Posts: 493 BFE
blue67440's
BFE
If your car is an auto and utilizes the 4 blade "34" fan then i'm pretty sure you need a 18259 32 spacer that is 1.24" thick.
If you find that's what you need I think I have a few good spares and I'll send you one.
blue
XP29L72 A833 in 881
XP29L72 A727 in 881
[Re: blue67440's]
#610875
02/13/10 10:59 AM
02/13/10 10:59 AM
mopar4ya
western PA
The car is a 4 speed. The spacer and fan I have came off of a 66 Hemi automatic. I thought they would have been the same??? maybe not. I don't have a 66 parts book. Could someone that has a book look them up? Thanks Dan
[Re: hemi70se]
#610878
02/13/10 04:47 PM
02/13/10 04:47 PM
mopar4ya
western PA
If you have a buildsheet it will tell you the last 2 #'s of the part # of the spacer you need. Look at the casting # under the spacer and find a match.
Why didn't I think of that , Thanks!
Dan
[Re: twodoorpost]
#610882
02/14/10 08:15 AM
02/14/10 08:15 AM
mopar4ya
western PA
Ok, I looked on my broadcast sheet, and sure enough it has the #32 on it. So the 1825932 spacer is what I need. Was lucky enough to have one here . Thanks! Dan
