Load range E 15" tires....any luck? #610144
02/10/10 11:36 PM
02/10/10 11:36 PM
Chowchilla,ca
Chassisman Offline OP
Chowchilla,ca
Are any of you out there running 15" load range E tires? My trailer needs new hides and I dont wanna throw good money after bad. So let's hear it.
Thx
Re: Load range E 15" tires....any luck? [Re: Chassisman] #610145
02/11/10 01:17 AM
02/11/10 01:17 AM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
I went to Towmaster 10 ply bias on my 28 ft Pace, loaded to Phoenix and back and a few trips over the hill so far so good.
Re: Load range E 15" tires....any luck? [Re: Chassisman] #610146
02/11/10 02:59 AM
02/11/10 02:59 AM
Cab_Burge Online work
Cab_Burge  Online Work
I have had two D and two E 15 incher trailer tires on my 8800 lb(loaded on the axles) Pace 24ft. trailer for the last four years I do use it regulary and keep the cold tire pressures about 5 lbs above the recommended pressure on the tire siewalls I had two blow outs at one time and could not get another two E rated tires at that time
Re: Load range E 15" tires....any luck? [Re: Chassisman] #610147
02/11/10 06:08 AM
02/11/10 06:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Check with Goodyear, they have a pretty good selection
on trailer tires(trailer only)
Re: Load range E 15" tires....any luck? [Re: MR_P_BODY] #610148
02/11/10 07:54 AM
02/11/10 07:54 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I put 4 E rated tires from Good Year on my 28ft trailer just last year. I'm at work now and can't remember the name of them but they seem to be a very good tire.
Russ
Re: Load range E 15" tires....any luck? [Re: max_maniac] #610149
02/11/10 08:03 AM
02/11/10 08:03 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Some time ago on here there was trailer tire discussion. What most were doing with great success was upgrading to a 16" wheel/tire package. If that's not an option some were recommending Maxxis(spelling) tire (load range 'E') at about $160 each. If that thread is archieved it is worth a read IMO. IIRC HemiJoel was a wealth of good info in that post. Either way, let us know what you came up with.
Re: Load range E 15" tires....any luck? [Re: HardcoreB] #610150
02/11/10 08:26 AM
02/11/10 08:26 AM
Colorado
506RR Offline
506RR  Offline
Colorado
I run 15" rims with Maxxis E load rating tires, and so far so good! I have had other tires like towmaster and goodyears blow out, but so far these Maxxis tires have been great!
Re: Load range E 15" tires....any luck? [Re: 506RR] #610151
02/11/10 01:56 PM
02/11/10 01:56 PM
Chowchilla,ca
Chowchilla,ca
I tried upgrading to 16"...but it's a triple axle 40ft Pace and the 16's run into each other.I think the Maxxis tire fits the bill....and what a bill it will be....6 tires and 2 spares...LOL
Local tire shop wants to sell me a set of Greenball Trailer tires....but I've never even heard of them.
Re: Load range E 15" tires....any luck? [Re: Chassisman] #610152
02/11/10 02:26 PM
02/11/10 02:26 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
I also went with the 10 ply Maxxis tires on my 26ft enclosed. The old tires were sunchecked so it was time. These tires are much heavier and have way stiffer sidewalls than the old 8 ply Goodyears that were on there previously. The reduced sidewall flex is very noticable when going around sharp corners. I like them
Ron
Re: Load range E 15" tires....any luck? [Re: max_maniac] #610153
02/11/10 02:32 PM
02/11/10 02:32 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Russ
Goodyear "Marathon". I've been running them on my 18' utility trailer for 10 years now, no problems, excellent tire.
Goodyear
The heaviest 15" is only a range "D"...
Ed
Re: Load range E 15" tires....any luck? [Re: firefighter3931] #610154
02/11/10 02:36 PM
02/11/10 02:36 PM
Chowchilla,ca
Chowchilla,ca
Anyone heard of Gladiators ????? A guy in the next town over has 225/75 15 E's for 57.50 ea...a huge RV dealership went under and it's full to the rafters with them.
http://modesto.craigslist.org/pts/1572121565.html
Re: Load range E 15" tires....any luck? [Re: Mr. Smurf] #610155
02/11/10 03:22 PM
02/11/10 03:22 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Russ
Goodyear
Ed
Mine are not the Marathon brand and they are an E rated 15" tire. I did get them from Goodyear but they do not have the Good Year name on them. If I remember tonight to get the name I'll post it. I did want the Maxxis tires but there are no dealers anywhere near me.
Russ
Re: Load range E 15" tires....any luck? [Re: max_maniac] #610156
02/11/10 05:32 PM
02/11/10 05:32 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Load range E 15" tires....any luck? [Re: max_maniac] #610157
02/11/10 06:04 PM
02/11/10 06:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Russ
Mine are not on that list either... I dont recall the
name of the tire but they were rated at 4200 lbs @
100 psi.... but I did get them from a Goodyear dealer
Re: Load range E 15" tires....any luck? [Re: max_maniac] #610158
02/11/10 10:45 PM
02/11/10 10:45 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Russ
Goodyear
Ed
Russ
The tires I got from Goodyear are TOWMAX STR tires. They are E rated 10 ply tires just for trailers and I think they were around $110.00 each. Like I said I just got them last year so they only have 1 year on them so far and we will see how good/bad they are.
Russ
Re: Load range E 15" tires....any luck? [Re: max_maniac] #610159
02/11/10 11:29 PM
02/11/10 11:29 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
My 24 foot enclosed Haulmark Edge came with 15" load range D tires. I had so many problems I stopped in Bakersfield and had them put "E" tires on it and cranked them up to 80psi and I have not had a problem since. The trailer tows noticably better too. I was not expecting that.
Ron.
http://www.discounttire.com/dtcs/findTir...IINT&cs=225
SRT DEMON ONE SEAT
Re: Load range E 15" tires....any luck? [Re: Ron Silva] #610160
02/12/10 12:07 AM
02/12/10 12:07 AM
Ontario,Canada
Ontario,Canada
I bought my Maxxis 10 ply ST225/75/15's from this seller. Very reasonable shipping too !
http://cgi.ebay.com/ebaymotors/BRAND-NEW...=item4a9e627e7c
Good luck Chassisman
Ron
