Pertronix Conversion #608817
02/09/10 02:59 PM
02/09/10 02:59 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Finally got the 36 back running after being under water in September. Ready to do the Pertronix. I know it has been gone over before but I am still finding conflicting info. To ballast or not to ballast that is the question. And what if you are using one of their coils? Thanks!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Pertronix Conversion [Re: 36PLYM] #608818
02/09/10 03:36 PM
02/09/10 03:36 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
When i installed mine several years ago, the instructions said not to ballast, that you needed a full 12 volts. I left my ballast in place just for looks and ran a jumper from one side to the other. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Pertronix Conversion [Re: rattler] #608819
02/09/10 04:18 PM
02/09/10 04:18 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Thanks, full 12 volts to the ignitor or full 12 volts to the coil? If wired according to Pertronix you get 12 volts to the ignitor(red wire before the ballast)and the coil is after the ballast. ??
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Pertronix Conversion [Re: 36PLYM] #608820
02/09/10 11:35 PM
02/09/10 11:35 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I"ll try to look at mine tomorrow and get back to you. Randy
Re: Pertronix Conversion [Re: rattler] #608821
02/10/10 04:47 PM
02/10/10 04:47 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
12v to the positive side of the coil, this is also where the red wire of the ignitor connects. Randy
Re: Pertronix Conversion [Re: rattler] #608822
02/11/10 05:54 PM
02/11/10 05:54 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Thanks guys for all the input. Got the Petronix finished today, it could not have been easier! I did away with the BR altogether since this is a street rod project everything is under the dash including the coil. What should be a good starting point for timing at the balancer? Should I go with a hotter plug?
Thanks again!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Pertronix Conversion [Re: 36PLYM] #608823
02/13/10 10:57 AM
02/13/10 10:57 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I always end up timing by ear. I run the timing up to just under spark knock. That is where the best power is going to be. As far as spark plugs go, you can stark by opening up the gap on your plugs because you now have more spark energy. I think i opened mine up to .045 and have not had to touch anything in the last few years.Randy
