Cuda gill stamping #608445
02/09/10 12:30 AM
02/09/10 12:30 AM
Chicagoland
cudastruction Offline OP
Chicagoland
Does anyone do the stamping anymore or does everyone buy that patch and weld it in?
Re: Cuda gill stamping [Re: cudastruction] #608446
02/09/10 12:46 AM
02/09/10 12:46 AM
Blenheim, Ontario Canada
BlenheimBoy Offline
BlenheimBoy  Offline
There was a guy in St. Catherines, Ontario stamping 71 fenders. Alittle bit far for u.
I can findout his name if needed. just PM me
Thx
Bill
Blenheim-Boy
Re: Cuda gill stamping [Re: cudastruction] #608447
02/09/10 02:18 AM
02/09/10 02:18 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
J&J in Conn. used to do that,....about $425 IIRC for a set of fenders to be done, the fender plates were offered by Tony's parts some time ago, but with the fenders being out by Goodmark......the last few years, there's very little need, unless something custom is in mind/
Re: Cuda gill stamping [Re: cudastruction] #608448
02/09/10 07:47 AM
02/09/10 07:47 AM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
Call Mike at B/E&A. You will not be disappointed.
http://www.beaparts.com/list_items.aspx?body=E&cat=E&subcat=37
You can also order a set of these:
http://www.beaparts.com/list_items.aspx?body=E&cat=E&subcat=27
Re: Cuda gill stamping [Re: JS29] #608449
02/09/10 08:42 AM
02/09/10 08:42 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
on a related note, if you are buying fenders, should you get the 71 and fit a 70 grill (or a 73 grill in my case) to the 71 fenders, or do you order the 72+ ones and weld the gills in?
What is the best?
How do 70-4 fenders swap?
Re: Cuda gill stamping [Re: cudastruction] #608450
02/09/10 09:24 AM
02/09/10 09:24 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Rich Deters from Arnold,Mo can do it ,he's a member on here but don't remember his site name.
He'll see this and respond soon.
logan426
Re: Cuda gill stamping [Re: 6T6Cuda] #608451
02/09/10 10:53 AM
02/09/10 10:53 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you require the 72-4 fenders and grille, I'd order the reboped 72-4 feders and send them off to be punched, you could arrange to have them drop shippied to the vendor of your choice for punching to cut down on shipping/damage in transit...the old weld in patches were hack job methods to alter exsisring non gilled fenders, if youvalue the car, do it right, do it once
Re: Cuda gill stamping [Re: DAYCLONA] #608452
02/09/10 11:52 AM
02/09/10 11:52 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
I had a guy in Iowa do mine- but I can't remember his name, and can't find his contact info. Someone here will know- probably the closest guy to you though-
Re: Cuda gill stamping [Re: Kirby] #608453
02/09/10 12:35 PM
02/09/10 12:35 PM
Chicagoland
Chicagoland
Here is my situation...my original 71 drivers side fender is too rotted to keep/fix. So, many years ago before repopped fenders existed, I bought an original 71 drivers side fender (no gills but a 71). I am now restoring the car and don't want a repop fender since I have an original one.
What way should I go...stamp it (by who?) or get the patch and weld it in?
The patch seems very simple but time at the shop is money...is it more money than me shipping one fender to someone for a stamping?
Re: Cuda gill stamping [Re: cudastruction] #608454
02/09/10 12:47 PM
02/09/10 12:47 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Get it stamped, in no way should you even consider the patch. Rich did a beautiful job on mine. Where are you from in ILL ? Rich is just south of St Louis
logan426
Re: Cuda gill stamping [Re: MLR426] #608455
02/09/10 12:53 PM
02/09/10 12:53 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
logan426
Rich is a real good guy. His user name is Sputnik...
Re: Cuda gill stamping [Re: 318 Stroker] #608456
02/09/10 09:13 PM
02/09/10 09:13 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Hi Al.
Email sent/replied.
I can still stamp the 71 Cuda' fender gill holes.
As a rule after the stamping the only bodywork required is very minimal body filler around the gill holes. (usually spot putty or heavy primer will handle it).
It eliminates the welding required to install the patch panels.(and the possible metal warping).
I charge $200 a fender.
I haven't had any complaints about how they turn out, everyone that I've done them for has been happy so far.
Re: Cuda gill stamping [Re: SNK-EYZ] #608457
02/10/10 08:53 AM
02/10/10 08:53 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Hi Al.
Email sent/replied.
Me included.
logan426
