Procharger & 572 Hemi #608337
02/08/10 10:17 PM
02/08/10 10:17 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
Hi All,
has anyone run a Procharger on a Hemi? What size would be 'about right' for a mild boost (<10lbs) 572 Hemi application (street car)??
Expect to have 9:1 comp & mild boost & EFI.
Looking for stand out power in a B Body 68 Charger street car.
Darren
Darren Beale
Keith Black Racing Engines®
Re: Procharger & 572 Hemi [Re: Keith Black®] #608338
02/08/10 11:44 PM
02/08/10 11:44 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Hi All,
Darren
These guys will know.
http://www.thesuperchargerstore.com/
Re: Procharger & 572 Hemi [Re: Keith Black®] #608339
02/09/10 10:32 AM
02/09/10 10:32 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I just finished this pump gas motor. Made >1000 HP at 12 pounds. Everyone knows me as the EFI guy, so I would have preferred using EFI, but this customer wanted a blow-through carb (I used CSU for the carb). I had some jetting issues that would have never come up with EFI.
9:1 CR, hydraulic cam, MSD BTM ignition, very nice idle. A perfect street motor. I decided to go 472" to better match the flow volume of the F1.
Bob at The Supercharger Store can walk you through everything.
Re: Procharger & 572 Hemi [Re: Mopar_Rich] #608340
02/09/10 12:51 PM
02/09/10 12:51 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You need to check out the Holy Hemi.. SMRE was a site sponsor... They have the bad custom bracket that mounts the Pro Charger in a reverse pattern..
How about 2000+hp froma Pump gas, cast intake Hemi!!
http://www.youtube.com/watch?v=4hSZjdlKz6c
Re: Procharger & 572 Hemi [Re: Bob_Coomer] #608341
02/09/10 12:58 PM
02/09/10 12:58 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
How about The Stig Jr.
Over 1000 hp with a small D1X procharger and a hemi
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Procharger & 572 Hemi [Re: Kam*Kuda] #608342
02/10/10 07:20 AM
02/10/10 07:20 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Has anyone ever tried a water injection on blown-EFI?? I've only seen it with blow-through
Re: Procharger & 572 Hemi [Re: Defbob] #608343
03/21/10 12:43 AM
03/21/10 12:43 AM
Oakley CA
69charger440_6pa Offline
Oakley CA
I run it on my vette. Works great
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Procharger & 572 Hemi [Re: Mopar_Rich] #608344
03/21/10 01:09 AM
03/21/10 01:09 AM
Boston,MA Area
Chris_R/T Offline
Chris_R/T  Offline
Boston,MA Area
What's a motor like that cost when all said and done?
Re: Procharger & 572 Hemi [Re: Chris_R/T] #608345
03/21/10 03:57 AM
03/21/10 03:57 AM
QLD Australia
QLD Australia
My guess is the 472 could cost anything depending on choice of parts & what you started with. $40k?
Thanks to everyone, and Rich in particular, it looks like the Hemi/F2 combination with EFI will produce about 1,500hp (intercooled).
Getting started on the engine build now.
Darren
Darren Beale
Re: Procharger & 572 Hemi [Re: Keith Black®] #608346
03/21/10 04:50 AM
03/21/10 04:50 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Darren
Your not going to get 1500hp with 10lbs of boost
You can make 10 lbs with a d1 maxed out.
I would talk with Steve Morris at New Era to get the correct low down on what to do.
Procharger tech sent me to him to get my correct cog sizes because they weren't sure on hemi stuff.
Re: Procharger & 572 Hemi [Re: Chris_R/T] #608347
03/21/10 12:04 PM
03/21/10 12:04 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
That one was about $28K with all new parts and dyno time.
Your not going to get 1500hp with 10lbs of boost.
A 540" Hemi with 15 lbs of boost, on 100 octane, and no intercooler, will make about 1250-1300. Add a good intercooler and you come pretty close to 1500.
I use Bob at The Supercharger Store for all my Mopar Procharger stuff. They have all the bracketry and they know the pulley sizes to get very close on the first try.
Re: Procharger & 572 Hemi [Re: Defbob] #608348
03/21/10 12:08 PM
03/21/10 12:08 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I've done it, Bob at The Supercharger Store suggested I try this (water and Meth) and it was easy pleasy... No negatives from what I could see except having more containers to fill.
The EFI didn't care.
Re: Procharger & 572 Hemi [Re: Mopar_Rich] #608349
05/06/10 11:21 PM
05/06/10 11:21 PM
New Zealand
V
vs2 Offline
vs2  Offline
V
New Zealand
How did you make out?
My Cuda has a KB588, FAST EFI and F1R. About 1050 hp @ 8psi and using water/meth injection.
