Need help,Spring went flying!!! #608302
02/08/10 10:12 PM
02/08/10 10:12 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
(Need help,Spring went flying!!!) Got my booster and m/c installed and the return spring went flying off on dissassembly.I forgot to take a pic of the asy.while taking apart,Can anyone help,Its off my 70 Superbee dics/drum inside brake linkage
Re: Need help,Spring went flying!!! [Re: Hemiruss] #608303
02/08/10 10:22 PM
02/08/10 10:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Is this the spring that attaches to the underdash linkage? if so look at the bracket that the steering column & pedals are mounted to.. above the "dogbone" shaped link that attaches the pedal to the bellcrank... there should be two slots.. One end of the spring hooks through those slots.. The other fits into the groove in the dogbone... It prevents rattles...
Re: Need help,Spring went flying!!! [Re: 1_WILD_RT] #608304
02/08/10 10:35 PM
02/08/10 10:35 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
I did see the groove in the dog bone but I couldnt find where the onter end went,so it hooks from the dog bone groove to the center on the bellcrank? and I noticed it "clicked" when I moved the pedal.I also haven't put in any fluid yet.
Re: Need help,Spring went flying!!! [Re: Hemiruss] #608305
02/08/10 11:07 PM
02/08/10 11:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not to the bellcrank.. Straight up to the bracket that the pedals are hung off of... Seriously look straight up from the groove in the dogbone & you'll see two slots in the support bracket.. Edited grabbed this picture off ebay.. The two slots that run acroos the bracket...You'll be looking at the bottom of this bracket..
Re: Need help,Spring went flying!!! [Re: 1_WILD_RT] #608306
02/08/10 11:17 PM
02/08/10 11:17 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Now I know what you mean,and again you saved my bacon.....Thanks
Re: Need help,Spring went flying!!! [Re: Hemiruss] #608307
02/08/10 11:18 PM
02/08/10 11:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Glad to help..
