? about 440 crank in low deck #608092
02/08/10 07:17 PM
02/08/10 07:17 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Hello
Everything I read seems to recommend cutting the counter weights for better fitment. What is the difference between an RB compared to a B in respect to the crank? I understand it being easier to balance but most advertisements say it is for fit. Can someone explain this to me?
Re: ? about 440 crank in low deck [Re: mac56] #608093
02/08/10 07:32 PM
02/08/10 07:32 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The diameter of the counterweights is different. the exact number I don't recall... But it ends up being close to .200" off it. I have also used them with no clearance issues. So "your results may vary"...lol Personally I won't use a factory crank anymore when there are cheap alternatives for a better peice that drops in. To have a factory one magged, stroke corrected, indexed, and ground/polished is $400. A 440Source B wedge main/counterweight crank is $600 or so for a new part that is much stronger.
Re: ? about 440 crank in low deck [Re: mac56] #608094
02/08/10 08:41 PM
02/08/10 08:41 PM
AndyF Offline
AndyF  Offline
The crankcase on a B engine is a little tighter so the RB crank hits. Typically a forged RB crank is too heavy for a 451 or 470 motor anyway so if you have to remove weight, and you have to gain clearance why not do both at the same time?
There are legit reasons for boring out the mains in a B block to the larger RB size so that is another way to solve one issue. That doesn't solve the clearance issue or the weight issue but it does allow you to use better main bearings and to use a stronger crank. Of course the block is a little weaker and it costs some money to bore the main line.
Re: ? about 440 crank in low deck [Re: AndyF] #608095
02/08/10 08:47 PM
02/08/10 08:47 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks Andy. That is where I was going with this. I did not realize there was a difference in the block other than deck height.
Re: ? about 440 crank in low deck [Re: mac56] #608096
02/08/10 09:33 PM
02/08/10 09:33 PM
NC
440Jim Offline
440Jim  Offline
NC
A typical RB forged steel crank has counterweight diameters around 7.50-7.55"
This attachment shows what I measured on one 400 block on the inner cylinders (4,6 or 3,5). I have seen the front and rear counterweights clear at 7.5" dia.
You can also grind the block, or put really oversize bevels on the counterweights to clear the block.
Re: ? about 440 crank in low deck [Re: 440Jim] #608097
02/08/10 09:42 PM
02/08/10 09:42 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks for the picture Jim. As they say worth 1000 words.
Re: ? about 440 crank in low deck [Re: mac56] #608098
02/08/10 11:39 PM
02/08/10 11:39 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Here's what it looks like after you run the CNC through it to remove that annoying area and radius it....
Re: ? about 440 crank in low deck [Re: CRE2004] #608099
02/09/10 01:22 AM
02/09/10 01:22 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
commonly accepted counterweight diameter is 7-1/4". I had my machinist use this dimension, and it balanced out very easily from there.
Re: ? about 440 crank in low deck [Re: mac56] #608100
02/09/10 02:21 AM
02/09/10 02:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m running a 413 crank w/the counter weights cut down and w/6.385 chevy rod and JE pistons, my bob weight is around 2230 grams,spins to 7000+ with ease and has been doing so for 10 years in two different combos. I don`t buy the strength bs(or lack there of)w/a stock crank as guys are runnin 8`s w/turbos using em. Don`t remember exactly how much was removed but it balanced out very nicely and was cheap.
Re: ? about 440 crank in low deck [Re: CRE2004] #608101
02/09/10 06:47 AM
02/09/10 06:47 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Nice work, but then you have a reputation for nice work. Was this done so the counter weight didn't have to be cut or were there other facts?
Re: ? about 440 crank in low deck [Re: mac56] #608102
02/09/10 08:43 AM
02/09/10 08:43 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I had a stock RB crank that dropped in with a minor amount of clearancing where Jim noted in the picture. This is why I say some do fit...
Re: ? about 440 crank in low deck [Re: moper] #608103
02/09/10 11:05 AM
02/09/10 11:05 AM
Puyallup, WA
Puyallup, WA
but even if it fits, what sort of swiss cheese does it look like after balancing it?? The counterweights are not only too large, they're too heavy for the 451 / 470 combo. Cutting them down helps both issues, probobly also helps reduce windage. Just seems like the right way to do it.??
Re: ? about 440 crank in low deck [Re: StealthWedge67] #608104
02/09/10 11:36 AM
02/09/10 11:36 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Re: ? about 440 crank in low deck [Re: supercomp] #608105
02/09/10 12:31 PM
02/09/10 12:31 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I used H-beams and J&Es with the one that dropped it. The rods were not light but the crank still had a few 1" holes in it. Not that I consider that a big deal. But it did make for a bit of work when balancing it.
Re: ? about 440 crank in low deck [Re: moper] #608106
02/09/10 06:31 PM
02/09/10 06:31 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
So then there is no trick to cutting the counter weights is there? Just put in a big a$$ lathe.
Re: ? about 440 crank in low deck [Re: mac56] #608107
02/09/10 07:07 PM
02/09/10 07:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Pretty much............
Re: ? about 440 crank in low deck [Re: Thumperdart] #608108
02/09/10 07:19 PM
02/09/10 07:19 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Thanks Thumper
Re: ? about 440 crank in low deck [Re: mac56] #608109
02/09/10 07:34 PM
02/09/10 07:34 PM
AndyF Offline
AndyF  Offline
There are several tricks to cutting down the counterweights. First off you need to know what dimension to cut it to. Then you need the right fixture to bolt to the crank flange so the lathe can hold the crank. It also works better if you have the right tool to center the nose of the crank. And the last trick is to have the correct type of cutting tool.
Re: ? about 440 crank in low deck [Re: AndyF] #608110
02/09/10 07:51 PM
02/09/10 07:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Let me re-phrese that(4 u Andy)it`s no problem for the machine shops that I deal with. How`s that?
Re: ? about 440 crank in low deck [Re: CRE2004] #608111
02/09/10 08:38 PM
02/09/10 08:38 PM
NC
440Jim Offline
440Jim  Offline
NC
That is nice looking.
