static vs. dynamic compression #608077
02/08/10 07:00 PM
02/08/10 07:00 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
I have been playing with the Wallace racing calculators and doing some thinking (very dangerous thing) which would be best to use to figure what fuel to use. With the figures I run I have 14.3/1 static compression but that converts to 11.65/1 dynamic so my question is should I run 110/112/114
Re: static vs. dynamic compression [Re: dbran451] #608078
02/08/10 07:07 PM
02/08/10 07:07 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
110
Re: static vs. dynamic compression [Re: blownzoom440] #608079
02/09/10 01:02 PM
02/09/10 01:02 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
I'll bump this once any other thoughts
Re: static vs. dynamic compression [Re: dbran451] #608080
02/09/10 01:28 PM
02/09/10 01:28 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i would think 110 would be plenty.
i'v been playing with that same calculator to figure pump gas use. its said that if you keep your dynamic compression under 9:1 your safe on pump gas, but is that with a cast iron head or an aluminum head? anyone know?
Re: static vs. dynamic compression [Re: mopar dave] #608081
02/09/10 02:38 PM
02/09/10 02:38 PM
western pennsylvania
b1dartsport Online content
b1dartsport  Online Content
My aluminum headed small block is 9.7 dynamic and 11.4 static and runs fine on pump on street & strip. I did a lot of smoothing ridges off pistons & combustion chambers while assembling it. I think another question in the equation is quench. I have mine set at .039. Tight quench makes a lot of difference in detonation resistance. Just my
Re: static vs. dynamic compression [Re: b1dartsport] #608082
02/10/10 05:01 AM
02/10/10 05:01 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
ok, my quench was .039, but will bee .040 with the new sce gasket.
