B10 Brake Code for 1970 E- Body? #607911
02/08/10 03:47 PM
02/08/10 03:47 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hi All,
I have been decoding my 1970 Challenger and have been able to decode everything except the "B10" brake code. The online searches I've done come up with no description of that one. I am pretty sure this was a power disc brake front, rear drum model, but would like to confirm.
Thanks!
Re: B10 Brake Code for 1970 E- Body? [Re: dg_dodge] #607912
02/08/10 04:08 PM
02/08/10 04:08 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Is the B10 in the lower right quarter of the tag? If so, its not a brake code, but scheduled production date.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: B10 Brake Code for 1970 E- Body? [Re: RoadRunner] #607913
02/08/10 04:18 PM
02/08/10 04:18 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Yes, it is in the bottom right quarter (2nd line from the bottom on the right, preceding a six-digit number - 040849). If so, any idea what that 6 digit code might mean? I had given up on figuring that one out.
Thanks a lot!
Re: B10 Brake Code for 1970 E- Body? [Re: dg_dodge] #607914
02/08/10 04:31 PM
02/08/10 04:31 PM
RoadRunner Offline
RoadRunner  Offline
Thanks a lot!
I think it is for November. I will be corrected if I am wrong, but I think A is October, B is november and C is December. Then 1 for January, 2 for February, 3 for March.... The factory used numbers 1-9 and letters to cover the whole 12 months of production.
2023 Ford Mach 1
Re: B10 Brake Code for 1970 E- Body? [Re: RoadRunner] #607915
02/08/10 04:46 PM
02/08/10 04:46 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
B10= nov 10th SPD dan
Re: B10 Brake Code for 1970 E- Body? [Re: RoadRunner] #607916
02/08/10 05:16 PM
02/08/10 05:16 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
The 6 digits after the S.P.D. is the V.O.N.--Vehicle Order Number...
Re: B10 Brake Code for 1970 E- Body? [Re: 318 Stroker] #607917
02/08/10 06:22 PM
02/08/10 06:22 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Great info! Thanks very much guys! I now have a complete decode of my fender tag. Your help is much appreciated!
