Are '70 Satellite, RR, & Belvedere Grilles the Same?
#607492
02/07/10 09:45 PM
02/07/10 09:45 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Are the factory grilles on '70 Plymouth Satellites, Road Runners and Belvederes the same? I'm building the Monogram '70 GTX kit as a Satellite and using the Road Runner kit's grille, as based on what I saw at www.hamtramck-historical.com , all three grilles appear to be the same, but maybe the small trim band around the grille's perimeter is the only difference? The grilles in the following two pics appear to be correct for a Road Runner (and maybe for Satellites & Belvederes, too): TIA.
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same?
[Re: pinkduster]
#607494
02/07/10 09:48 PM
02/07/10 09:48 PM
In_The_Pink
Milwaukee, WI
They are the same, but the paint is different.
Please elaborate. Color? Texture?
[Re: mr_belvedere]
#607496
02/07/10 10:03 PM
02/07/10 10:03 PM
In_The_Pink
Milwaukee, WI
In the pics you posted, you can see the outer band of the grille/bezels is light textured argent, with the vertical fin areas med. textured argent. A standard Satellite/Belvedere grille is the exact opposite, outer band med. textured argent.....
Great info. Thank you both.
[Re: challenger2008]
#607499
02/11/10 09:39 AM
02/11/10 09:39 AM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
The Sport Satillite (2dr, 4dr, vert or wagon) and GTX have the honey comb grill
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: In_The_Pink]
#607500
02/11/10 10:57 AM
02/11/10 10:57 AM
Posts: 3,365 St.Louis,Mo.
70RR383
St.Louis,Mo.
Satellite and belvedere also did not have plymouth off to the side,it had a red,white and blue emblem in the CENTER.Its a emblem that is about 8" long by 1 or 1 1/2".
[Re: 70RR383]
#607501
02/11/10 05:26 PM
02/11/10 05:26 PM
Posts: 1,304 Northern Indiana
mr_belvedere
super gas
super gas
Northern Indiana
Sorry, but SPORT satellite was the only '70 PLymouth b-body that used the red/white/blue emblem in the center of the grille.
Belv., Sat., RR all used the 'Plymouth' emblem on the left side of the grille.
