Toggle switch......do they make #606614
02/07/10 12:52 AM
02/07/10 12:52 AM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
do they make a 3 position toggle switch were the Middle would be "off", one way be a momentary "on", then the other be a constant "on"?
Re: Toggle switch......do they make [Re: Bob_Coomer] #606615
02/07/10 01:24 AM
02/07/10 01:24 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Yes they are made. Not sure where to get one but they are used in the rear engine compartment on old GMC transit buses if I remember correctly.
Re: Toggle switch......do they make [Re: Bob_Coomer] #606616
02/07/10 01:42 AM
02/07/10 01:42 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Either of these work?
http://www.summitracing.com/parts/LNG-45490/
http://www.summitracing.com/parts/ARC-2140/
Only things I found that were close
Re: Toggle switch......do they make [Re: Bob_Coomer] #606617
02/07/10 01:42 AM
02/07/10 01:42 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Terminal Supply has them...
http://terminalsupplyco.com/Store/Product.aspx?pc=1244%2f20
The (on) means momentary...
Re: Toggle switch......do they make [Re: OzHemi] #606618
02/07/10 11:29 AM
02/07/10 11:29 AM
Lenox, MI
gj69charger Offline
gj69charger  Offline
Lenox, MI
Re: Toggle switch......do they make [Re: Bob_Coomer] #606619
02/07/10 11:39 AM
02/07/10 11:39 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am sure that NAPA would be able to get them also.
Re: Toggle switch......do they make [Re: blownzoom440] #606620
02/07/10 11:44 AM
02/07/10 11:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
69 GTX 68 Road Runner
Re: Toggle switch......do they make [Re: JERICOGTX] #606621
02/07/10 12:58 PM
02/07/10 12:58 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Make sure the switch has the DC current carrying capacity for the circuit where you are using it. AC and DC current capacity are not the same and a lot of switches are only rated for AC use.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
