Page 3 of 3 1 2 3
Re: Double flare tubing tool [Re: 71scamp440] #605794
02/08/10 11:52 AM
02/08/10 11:52 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
get an otc stinger part number 4503. we sell them over the counter at my work for $33.85. it hasnt let me down yet. used it twice last week with no issues.
I "rented" that exact kit from Autozone for $25 deposit, and never returned it. Before you jump on me, it was at the counterman's advice. He said if I liked it I should just keep it. They couldn't necessarily sell them, but they could replace non-returned rentals with another one. I just used it again last night to do the custom lines on my new Dana. Never slipped once and does really nice flares.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Double flare tubing tool [Re: Moneypit6] #605795
02/08/10 12:28 PM
02/08/10 12:28 PM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
Making sure the end you're flaring has some silicone spray lube on it will help keep the flaring device from pushing it through the clamp.
Re: Double flare tubing tool [Re: pyp1000] #605796
02/08/10 01:07 PM
02/08/10 01:07 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Vice-Grips.
Now I wish I would have taken some pictures of the kludge I worked out to get my Summit double flare tool to work. As already stated, tighten the sucker until both ends bottom out. Then put the rest of the thing together like you are going to use it but don't start yet. Now take a pair of Vice-Grips and use them to squeeze the bulge in the tube clamp together. I've done several things like this from 1/4 to 3/8 and have had good luck so far.
I made the fuel lines (the 5/16 part going up to the brass-T and the 3/8 attached to the carb -- the 5/16 really snakes around and I did not want to have to do it twice and I made these trans cooler lines to go hug the frame [only showing 1])
Re: Double flare tubing tool [Re: Chilort] #605797
02/08/10 01:21 PM
02/08/10 01:21 PM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
Here we go, a picture is worth a thousand words.
Re: Double flare tubing tool [Re: Chilort] #605798
02/08/10 02:01 PM
02/08/10 02:01 PM
GA
roadrunninMark Offline
GA
This is a real good thread, I am coming up on having to do some brake line bending and flaring too! Is it true that you cannot double flare stainless steel lines? What is the best tube size to use to run for brakes? I will be using disc brakes at both ends.
Mark
Re: Double flare tubing tool [Re: roadrunninMark] #605799
02/08/10 02:19 PM
02/08/10 02:19 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
After clamping the tubing into the holder, I clamp the holder into my vice so it smashes the holder flat and grips the tube. The fitting always covers up the grip marks when finished.
Re: Double flare tubing tool [Re: Lefty] #605800
02/08/10 10:34 PM
02/08/10 10:34 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Another cool thing about the Mastercool kit is that you can buy replacement parts. I wore out the 3/16" gripping die and got a replacement for $15.
Re: Double flare tubing tool [Re: Lefty] #605801
02/09/10 09:25 AM
02/09/10 09:25 AM
California
Moneypit6 Offline OP
California
I ended up putting it into a vise, tightening up both locks, loostening the vise to reposition the clamp so I could get the tool over the tube. Re-tightening the vise right next to the tool. Tighten up the tool and it pushed the tube out the bottom. It did make a part of the flare but not enough. Removed the tool from the clamp and the tube had been noticeably squeezed to a smaller diameter.
So, gave up. Ordered the mastercool kit. Hope it works.
Also, most of the tube comes in coils. Is there a trick to straightening it so that it looks ... straight?
70 Roadrunner almost ready to come off the rotisserie smile
Re: Double flare tubing tool [Re: Moneypit6] #605802
02/09/10 11:04 AM
02/09/10 11:04 AM
Australia
dodgy Offline
dodgy  Offline
Australia
yep grab a chunk of wood 4x3/4x4 and drill the next size up to your tube in it, mount the wood with the hole in it in your vice and pull the line through the hole.maybe i could have explaned that better, but you know what i'm thinking i hope.
Luke
Re: Double flare tubing tool [Re: Jeremiah] #605803
02/09/10 11:05 AM
02/09/10 11:05 AM
USA
Slider Offline
super gas
Slider  Offline
super gas
USA
My a/c crimper is a Mastercool, they seem to make real nice stuff
I have a Mastercool setup and it is awesome. Factory looking flares without having to remove the line from the car after you bend it up.
The main problem with the flaring tools that are sold is that they are made for "thin wall" tubing. I have yet to see a parts store that sells said think wall tubing. Did you ever notice that your tubing vice (the thing that holds the tube) makes the tube oval when tightened down? This is because you are using thick wall tubing. I have never seen a cheapy double flaring kit made for "thick wall" tubing.
Have been following this thread with interest. Ran across this description on Amazon, of thier Ridgid 345 flaring tool:
<i>Product Description
Item #: 632-23337. All flaring tools listed are recommended for soft materials such as aluminum and soft copper
No. 454W, No. 455, and No. 375 will also flare steel, <b>stainless steel</b>, hard copper, and brass
No. 458R and No. 377 will flare steel, <b>stainless steel</b>, hard copper, and brass thru wall thickness of .035 inches
No. 345 is a precisioin designed tool for producing 45§ flares in soft copper. brass. aluminum, and mild-steel tubing. A hardened, smooth cone provides fast, 45§ flares either single or double lap. A single clamp screw provides for easy clamping and removal of tubing</i>
Not reccomending a Ridgid, just for additional info. 458R was about $120.
�Hunt down those Chevies and Fords and crush �em like bugs!� ~ Tom Hoover
(O=o=====o=O)
Re: Double flare tubing tool [Re: Slider] #605804
02/10/10 01:39 PM
02/10/10 01:39 PM
California
California
Well, got the Mastercool flaring kit by UPS after my $320 payment. Put small 45 degree bevels on the line. Locked it in the locking jaws and tightened up till it was very tight with the blocks bottomed. With the tool in place and adjusted, I squeezed the hydraulic handle as I half shut my eyes in fear. The other half of my eyes watched as the tubing pushed right out the bottom of the die!!!!! Noooo!!! It did absolutely no better at holding the tube than the cheaper tools did.
I don't see any way it will work unless I grind the outer diameter of the tube down to weaken it. It's 3/8" steel tubing with a .028 wall. That would be counter productive on a fuel line to thin it out more I would think. I'm confused about how so many people don't have any problems doing this unless they are using it on smaller tube.
Re: Double flare tubing tool [Re: Moneypit6] #605805
02/10/10 02:03 PM
02/10/10 02:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Wow...320 bucks?
Like somone said above, get some different tubing. Sorry about your trouble.
Re: Double flare tubing tool [Re: Challenger 1] #605806
02/10/10 06:46 PM
02/10/10 06:46 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Get different tubing... just like copper wire that is now made to the low end of the spec , so is tubing (usually offshore)
Re: Double flare tubing tool [Re: Moneypit6] #605807
02/10/10 07:40 PM
02/10/10 07:40 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
, I'm a big proponent of the MasterCool solution, hope someone can step and give a suggestion, when you start with brake lines in SS you will feel better.
Re: Double flare tubing tool [Re: Moneypit6] #605808
02/10/10 08:56 PM
02/10/10 08:56 PM
Lefty Offline
Lefty  Offline
Some things come to mind...
Clean the line and clamping die with brake clean to make sure there's no oil.
If you are using SS line like Summit sells you have to anneal the end of the line before flaring. I know the ad says it's already annealed, but trust me, it needs to be done again. I use my jet flame cigar lighter pointed at the end until it starts to turn golden, then let it air cool till it's cool to the touch.
Look at the clamping die on the back where the size is stamped. It should be indented where the "45 Inverted" is stamped and the print should be at 90 degrees to the "3/16" stamping. If not, it's the older design. Call Mastercool and ask for tech support. They will probably send you out the newer design clamping die.
You have to bevel the outside edge of the line as in the instructions.
Hope this helps...
Re: Double flare tubing tool [Re: pyp1000] #605809
02/11/10 09:48 AM
02/11/10 09:48 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I do that too. Usually oil in the die.
Another thing is to file the outside edge a bit and debur the inside. Extra material just makes it harder to flare the extra material.
As for the clamp. Once they slip, they teeth holding the line just get worn out.
Re: Double flare tubing tool [Re: Magnum] #605810
02/11/10 10:54 AM
02/11/10 10:54 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Re: Double flare tubing tool [Re: 2fast4yourBrain] #605811
02/11/10 12:35 PM
02/11/10 12:35 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I do and it works very well for my purposes. I use the 37 degree for AN fittings. Not super quick for production line work but works well for me.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Page 3 of 3 1 2 3
