short oil filter on a small block #605725
02/06/10 11:10 AM
02/06/10 11:10 AM
@ the shop
E
E-85 408 DART Offline OP
E
@ the shop
i need the part # of the short oil filter for the small block when using hooker 5204 headers & no 90* . or are you guys running remote oil filters ? my machinest isn't fond of the mopar 90* mopar oil filter !! thanks Brad
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: short oil filter on a small block [Re: E-85 408 DART] #605726
02/06/10 11:27 AM
02/06/10 11:27 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
just go to any parts store look up a filter for one of the 2.2 or 2.5 k cars. they are much shorter.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: short oil filter on a small block [Re: kilroy] #605727
02/06/10 05:54 PM
02/06/10 05:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you need shorter and smaller diameter you can use a Neon oil filter. I use toyota oil filters on my motors since I work at a toyota dealer.
Fram number to cross referance to a good filter go like this but please do not use a fram.
PH8a is a big filter both in diameter and length and if possible this is the size to use.
Ph16 is the shorter version but it is still big around
PH3614 is the neon style filter and has a small diameter and short length.
I think the PH3600 will fit also and is long and skinney.
All 3 of the first filters use the same diameter oring and thread size so they will all work as far as atatching to your motor. I know the PH3600 uses the same diameter seal and I am 90% sure the threads are the same. Been 10 years since I worked at wal-mart but remember the numbers still
Just promise not to actually use the fram filter, just use the number for cross-referancing.
Re: short oil filter on a small block [Re: HotRodDave] #605728
02/07/10 03:25 PM
02/07/10 03:25 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
"PH8a is a big filter both in diameter and length and if possible this is the size to use. "
Dave I thought this too but last time I was at autozone picking up a filter they listed ph43 for the small block. Wonder what the different is?
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: short oil filter on a small block [Re: blk00rt] #605729
02/07/10 03:29 PM
02/07/10 03:29 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: short oil filter on a small block [Re: 70AARcuda] #605730
02/07/10 04:26 PM
02/07/10 04:26 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
I use Purolator PL14670 with those headers.
Re: short oil filter on a small block [Re: abodiesonly1] #605731
02/07/10 08:47 PM
02/07/10 08:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I use the 2.2 type filter the FRAM (and other number is) 3614.
