Budget 360/ 450 HP #605034
02/05/10 03:22 PM
02/05/10 03:22 PM
northeast texas
strokin73cuda Offline OP
northeast texas
I have a 360 whats the best way to get 450 flywheel hp?
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Budget 360/ 450 HP [Re: strokin73cuda] #605035
02/05/10 03:26 PM
02/05/10 03:26 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
A 200 shot should do it.
Re: Budget 360/ 450 HP [Re: goldmember] #605036
02/05/10 03:36 PM
02/05/10 03:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Wow about cast crank strokers for 450hp:
360 LA or/vs 360 magnum?
E-brock vs RHS vs X or J head?
Like this maybe with smaller cam??? Which cam?
https://board.moparts.org/ubbthreads/show...e=0#Post5784366
Re: Budget 360/ 450 HP [Re: autoxcuda] #605037
02/05/10 03:42 PM
02/05/10 03:42 PM
northeast texas
northeast texas
I have a set of untouched j heads and its a la. Would magnums be better. And cast stroker would be fine wheres the best place to buy one?
Re: Budget 360/ 450 HP [Re: strokin73cuda] #605038
02/05/10 03:52 PM
02/05/10 03:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm asking the questions along with you. I'm in about your same situation.
Question: Least expensive path to 450 hp that's easy on the valvetrain/parts, not a lot of maintance, and a small enough cam that not going to lug and lope real hard?
And the parts you have lying around do factor into the budget. What size valves are in those J Heads you have? That may factor in the decision making.
Re: Budget 360/ 450 HP [Re: autoxcuda] #605039
02/05/10 03:59 PM
02/05/10 03:59 PM
northeast texas
northeast texas
1971 j heads from a 340 thier not here so I'm not sure. Just looked them up 1.78 in. 1.50 ex.
Re: Budget 360/ 450 HP [Re: strokin73cuda] #605040
02/05/10 04:08 PM
02/05/10 04:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Should be 1.88 in and 1.60 ex at least if they are J head.
I thought 71 340 J's are 202 in and 1.60 ex but may have switched to smaller 1.88 intake late in production??? Don't know about that.
Re: Budget 360/ 450 HP [Re: autoxcuda] #605041
02/05/10 04:12 PM
02/05/10 04:12 PM
northeast texas
northeast texas
ok the are 1970 340 t/a head just called the shop
Re: Budget 360/ 450 HP [Re: strokin73cuda] #605042
02/05/10 04:21 PM
02/05/10 04:21 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Really???
If so, sell the T/A heads and get a set of RHS x heads from Brian at IMM/indio Motor.
Getting 450hp from a 360 shouldn't be too tough and the RHS x heads would support it no problem.
Check out the 408 build he just did in the race forum.
Re: Budget 360/ 450 HP [Re: strokin73cuda] #605043
02/05/10 04:22 PM
02/05/10 04:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
With offset T/A rockers?? I'd get some pics of it to make sure about the ID.
If they are real T/A head you can sell those T/A head cores and pay for some rebuilt or new heads that are better and maybe some money left over for the rest of the motor build.
Re: Budget 360/ 450 HP [Re: autoxcuda] #605044
02/05/10 10:12 PM
02/05/10 10:12 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Not to race dyno sheets...but consider this one also.
Jesse Lackman built a very stout 520hp/540tq stroker. 408 based on Magnum block
Extremely mild, very streetable stroker....
https://board.moparts.org/ubbthreads/show...rue#Post4070225
-RHS 360HPST iron heads, 2.02/1.60
-Hughes 236/242 @ .050 Hyd roller .557/.521 lift
-stock Magnum hydraulic roller lifters
-Dove/Racer brown rockers 1.6 intake 1.5 exhaust
-Performer RPM Air Gap -Holley 870 Street Avenger
-1 5/8 x 2 3/4 dyno headers
-91 octane pump gas
-12.5 manifold vacuum @ 950 RPM
-398 CTQ @ 2000 RPM
-542 CTQ peak @ 4300 RPM
-520 CHP peak @ 5900 RPM
-500 CTQ from 3200 to 5200 RPM
Re: Budget 360/ 450 HP [Re: strokin73cuda] #605045
02/06/10 01:05 AM
02/06/10 01:05 AM
SoCal
Brian Hafliger Offline
SoCal
Best way or cheapest way? Either mild port eddy heads or these RHS heads will do.
10.3:1, hyd cam around 240@ .050 like Comp 285HL, rpm intake, 750 holley and good headers.
Lets not forget quality machine work!!
Brian Hafliger
Re: Budget 360/ 450 HP [Re: Brian Hafliger] #605046
02/06/10 02:05 AM
02/06/10 02:05 AM
PA USA
flatiron Offline
flatiron  Offline
PA USA
Well this is what I'm putting together. Sounds kinda like what your looking for.
1979 360
Purple cam Mopp4120233 with matching springs and lifters
cast crank and stock rods
.03 KB190
Sealed power rings ZE-251K30
Summit bracket racer damper
Summit double roller timing chain
Cloyes tennsior
B&M Flexplate
Crosswind intake
2.02/1.6 J heads ported and polished
Prw 1.5 ratio stainless roller rockers
Bored .03 over, Square decked to 9.588 and rebalanced
Clevite rod and main brgs
Actually making the road trip to Summit to pick up my goodies today
Re: Budget 360/ 450 HP [Re: flatiron] #605047
02/06/10 08:50 AM
02/06/10 08:50 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
My 406" is in your range of power.
97' 5.9 magnum block .020 over
MP cast 4" crank (got it from a friend for 200 bucks)
Eagle Rods (I Beam)
Ross Pistons
Basic Rings from Ross
MP Hyd Roller camshaft, forget the part# and duration, its the crate motor shaft with .501 int/ .513 ext.
Iron Ram heads, stock size 8mm valves and beehives. OOTB
MP 1.6 Roller Rockers
M1 single plane intake w/ 1" super sucker
Proform 750 cfm carb
1 5/8" basic headers
Summit Balancer
B&M 904 Flexplate
And the most important: QUALITY machine work !!
Richard Hotard did the crank and a quality race formate shop did the rest of the machining.
Setup have been extremely durable and very low maint. Very streetable.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Budget 360/ 450 HP [Re: Brian Hafliger] #605048
02/06/10 02:30 PM
02/06/10 02:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What about a 4" stroker 360 block to 450hp?
That will live off of junk california 91 octane Arco gas?
My situation is 85.21 miles to Willow Springs at 3800 rpm cruising. Then run the car on the big track from 8am to 5pm with one 15 minute session per hour. Then drive back. And it's my car to go to the grocery store with too.
Re: Budget 360/ 450 HP [Re: StandOnIt] #605049
02/06/10 03:48 PM
02/06/10 03:48 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
Eagle Rods (I Beam)
Ross Pistons
Summit Balancer
B&M 904 Flexplate
May i ask, what does it run? Sounds like a good build for my duster.
Re: Budget 360/ 450 HP [Re: forphorty] #605050
02/08/10 10:14 AM
02/08/10 10:14 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd start with a magnum block, stock crank, stock rods w/good bolts. KB107's at 0 deck
eq318B's, RHS X or edelbrock heads, will be ~10.5-11:1 range
use stock magnum roller lifters, and a roller cam in the .340" lobe lift, and 230@.050" range
eddie RPM air gap, and probably an 800cfm eddie thunder series carb, and full lenght headers.
2017 Grand Cherokee Overland
Re: Budget 360/ 450 HP [Re: patrick] #605051
02/08/10 10:36 AM
02/08/10 10:36 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I recently tested a mild 360 that went in a 66 Dart, the engine created 358 hp with no problem.
dual plane intake
650 edelbrock 800 made no more HP
mild cam lift in the 480's {don't remember specifics}
cast iron J heads with no extra work.
roller rockers
flat top pistons {approx. 9 to 1}
balanced rotating components
This was a fun engine to test!
sipped the premium pump gas and ran Smooooth.
According to the volumetric efficiently of this combo a set of heads {more flow} larger cam, more compression and the 800 carburetor {or larger} would be the next upgrades.
good luck on your build
