Re: 383 to 440(69 superbee)
[Re: 1hirschdalemopar]
#604264
02/04/10 10:00 PM
02/04/10 10:00 PM
340dart4spd
Parts Problem
Parts Problem
I am going to a 440 with a performer rpm intake and I was wondering if it would fit with the ramcharger hood and air cleaner set up?I want to keep the motor as stock looking as possible,and I will be running a holley 850.Thanks
pretty sure your going to have a little issue.....with the carb....
[Re: repad]
#604268
02/04/10 10:30 PM
02/04/10 10:30 PM
340dart4spd
Parts Problem
Parts Problem
I am going to run into the same issue..have not crossed that bridge yet..gonna run the 383 I have until the 440 is done....
I am 100% sure I will deff need to change intake..LOL
#604270
02/04/10 10:36 PM
02/04/10 10:36 PM
340dart4spd
Parts Problem
Parts Problem
Thanks for the replies,that a real bummer because I really want to run that set up,but maybe I will try for a modified air cleaner base or I may just have to come up with a different intake that performes close to the rpm intake.Any ideas on a different intake?
I intend to mock up stock application then do some simple math....
prob going to leave off air box..until later date....
[Re: Dougsmopars]
#604273
02/04/10 10:49 PM
02/04/10 10:49 PM
340dart4spd
Parts Problem
Parts Problem
I'm not sure but i beleive the air cleaner for the 440 cars is different from 383 cars. Lower profile. Look into that. Check your air cleaner against your brothers.
yes it is..the 440 one is shorter.. been there done that.....
#604278
02/06/10 01:03 AM
02/06/10 01:03 AM
RapidRobert
the 440 decks are going to be ~.745" (3/4") taller than your 383 out at a 45 angle which will translate to less than 3/4" of a vertical height change. The street dominator is a tried & true intake and might not be the perfect intake for your app (I am not sure) but yes it is a (very) low profile piece and I dont think it would hurt you in your app.
#604280
02/06/10 01:37 AM
02/06/10 01:37 AM
RapidRobert
this is my low deck street dominator that's going on my 451. EDIT 20 yrs ago nationally known Mopar racer Bill Bagshaw made 511 horsepower w a 30 over 440 w 6 pack (2355) pistons (9.5:1 CR) HOME ported 906 heads w the MP 2.08/1.74 templates (plastic sheet patterns were cut out larger), a box stock 750 (4779) holley dp and you guessed it a street dominator intake . You're not gonna be makin more than 511 are you
