Door jam, dome light switch question #603420
02/04/10 09:31 AM
02/04/10 09:31 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I'm looking for the door jam, dome light switch with the three pin plug. Rather than the one or two flat blade plugs ins. Anyone know where to get this? The switch in question is on the drivers side only on my car. Why? Who knows!
Re: Door jam, dome light switch question [Re: bigblock340power] #603421
02/04/10 09:35 AM
02/04/10 09:35 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
good luck,
3 blade AND the 3 pin switches both are very tough to find
Re: Door jam, dome light switch question [Re: bigblock340power] #603422
02/04/10 09:54 AM
02/04/10 09:54 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
They did that to isolate grounding for key in ignition buzzers, time delay lights and other fancy stuff. You can isolate the grounds using diodes and sharing a lug on a two lug switch. It was cheaper for the factory to make a three lug switch than add a couple of diodes to keep the circuits from talking to each other. Also lowered the parts count and increased the time before failure.
To hook them up, get a female lug of the same size as the switch. Hook the two cathode ends of 1N4001 diodes to the lug and hook each anode end (the one with the white stripe next to it) to each of the two wires from the harness. You can get the diodes or a substitute from Radio Shack. Total cost of all the lugs, spades and diodes will be less than ten bucks.
Craig
Re: Door jam, dome light switch question [Re: denfireguy] #603423
02/04/10 11:59 AM
02/04/10 11:59 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Door jam, dome light switch question [Re: mopars4ever] #603424
02/04/10 01:33 PM
02/04/10 01:33 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
I thought thats was because of the map light option. i found one on ebay last year way less than that. that guy is trying to bend someome over. Anyway they are hard to come by. Advance sells one but it has blades instead of pins. the other hard part is finding one wit the larger size hex nut. i have been thinking about either welding the hole up smaller and taping it or just drill another hole and use the smaller one. of course this wouldn't work if u are doing a 100 point restore. just my
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Door jam, dome light switch question [Re: 65cuda] #603425
02/04/10 05:26 PM
02/04/10 05:26 PM
indiana
generallee6901 Offline
indiana
As far as i know no one sells new ones that are the pin type.Used is probably your only option.71 b-bodies also used these.Not sure about 72 b-bodies though.
Re: Door jam, dome light switch question [Re: generallee6901] #603426
02/04/10 08:37 PM
02/04/10 08:37 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
I had the pin type in my 71 duster and a 72 dart i have. both had the map light. so they went at least 2 years.
Re: Door jam, dome light switch question [Re: 65cuda] #603427
02/05/10 06:39 PM
02/05/10 06:39 PM
Elk Grove, Calif.
Elk Grove, Calif.
WOW, these are a bit steep!
http://cgi.ebay.com/ebaymotors/Mopar-NOS...sQ5fAccessories
I'll try to look around a bit first, but this could be the only way I can go. And yes I do want it as close to original as possible.
