Vacuum pots-440 6pak #60312
05/20/08 01:45 PM
05/20/08 01:45 PM
Nova Scotia
gearbanger Offline OP
Nova Scotia
Bought a nice set of 440 six-pack holley carbs from a drag racer who had the out-board carbs set up as mechanical secondaries. I want to re-vacuum these carbs and I have new vacuum diaphram rubbers, but I don't have the aluminum diaphram pots that bolt to the side of the front and back carbs. Any ideas on where to get them? TKS.
Re: Vacuum pots-440 6pak [Re: gearbanger] #60313
05/20/08 01:49 PM
05/20/08 01:49 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Check w/ Pro Max, one of the site sponsors listed on the home page of this place.
Re: Vacuum pots-440 6pak [Re: gearbanger] #60314
05/20/08 01:55 PM
05/20/08 01:55 PM
SE Pa.
LimeliteAero Offline
SE Pa.
a few years ago I had a local parts joint order them up.
Re: Vacuum pots-440 6pak [Re: gearbanger] #60315
05/22/08 07:44 AM
05/22/08 07:44 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Try a look at these sites. Some are pretty pricey tho, so be prepared for a shocker...
http://www.sixpackperformance.net/home.php?cat=309
http://rain.prohosting.com/motrefok/list.html#sixpack
A True Hybrid: Burns Gas AND Rubber!
Re: Vacuum pots-440 6pak [Re: fastnos] #60316
05/22/08 04:49 PM
05/22/08 04:49 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
If you haven't already, be sure to verify the orifices weren't plugged when they were switched to mechanical secondaries.
Re: Vacuum pots-440 6pak [Re: SSAAHemiFan] #60317
05/22/08 06:49 PM
05/22/08 06:49 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
They have 'em on e-bay. New pair for around $124.
