Sonic Test #603146
02/03/10 09:43 PM
02/03/10 09:43 PM
Edgartown, MA/ Greene, ME
CharlieB Offline OP
CharlieB  Offline OP
I'll be picking up my 400 Block (stock -late 72 3698630) tommorrow after a cleaning, magnaflux and sonic test. I'm planning a race only 500-512 stroker build. Before I put any money into this block what should I be looking for in cylinder wall thickness. He's got a full printout of each cyl.
Re: Sonic Test [Re: CharlieB] #603147
02/03/10 10:08 PM
02/03/10 10:08 PM
CharlieB Offline OP
CharlieB  Offline OP
I found some info in the Tech Archives, but not sure of what I'm reading LOL- didn't seem to come to a conclusion. Looking for some "real life" info.
Re: Sonic Test [Re: CharlieB] #603148
02/03/10 10:15 PM
02/03/10 10:15 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
For race only, most builders like to see at least 0.200" on the major thrust surfaces. I brought 3 blocks to BG and two didn't meet his criteria. We are making about 700 HP.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Sonic Test [Re: CharlieB] #603149
02/03/10 10:18 PM
02/03/10 10:18 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What exactly is "minimum thickness" is a point of debate. I own a good tester and I use .120 as a minimum thickness on major thrust (that's the right side wall of each hole when looking down on the engine from the rear). Some go .150, some say .200. It should be between your machinist and you, and thicker the better. Sleeve holes if you dont have extra blocks and fine a thin one or two. If you can scan and post the results it might be easier for others to comment.
Re: Sonic Test [Re: moper] #603150
02/03/10 10:32 PM
02/03/10 10:32 PM
CharlieB Offline OP
CharlieB  Offline OP
I'll scan the results when I pickup the engine thanks
Re: Sonic Test [Re: moper] #603151
02/03/10 11:01 PM
02/03/10 11:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have seen 400 blocks raced(N/A only) sucessfully with .120 wall thickness on the major thrust for hundreds of runs, these where 13.0 to 1 motors tuned properly for no detonation on good quality race gas One of them had a small spot on the front of one cylinder that sonic .090 at the top and .072 at the bottom of that cylinder, I recommended not using it but he did anyways, sucessfully for four years chasing NHRA points in SG all over the country
Re: Sonic Test [Re: Cab_Burge] #603152
02/11/10 10:12 AM
02/11/10 10:12 AM
CharlieB Offline OP
CharlieB  Offline OP
Here's the test results what do you guys think?
Re: Sonic Test [Re: CharlieB] #603153
02/11/10 01:41 PM
02/11/10 01:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Is that before or after boring/freshening the block? If not deduct the material removal amount from the numbers on the thrust sides and adjust your numbers accordingly. Ideally most engine builders I know prefer 150 plus on the thrust sides, the more the better. Lower numbers (say 110-150) are probably fine for a mild to moderate street strip build.
Re: Sonic Test [Re: CharlieB] #603154
02/11/10 02:44 PM
02/11/10 02:44 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Okay just so I understand this. Lets use the OP's numbers and assume they are for a block that has not been bored yet. I notice that the #1 hole is off in one direction (I assume core shift) - thrust side 173 and non thrust 180. Can you just push the new bore toward the non-thrust side to cut as little as possible from the thrust side. How much movement of the bore can a block sustain without having geometry problems relative to the crank, rods, pistons etc.
Re: Sonic Test [Re: Runnin74] #603155
02/11/10 02:53 PM
02/11/10 02:53 PM
There are probally not to many machine shops that can successfully offset bore a V8 automobile engine block to compensate for core shift
Re: Sonic Test [Re: Runnin74] #603156
02/11/10 02:57 PM
02/11/10 02:57 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Keep in mind a .040 over will only take .020 off on each side of the cylinder.
Getting old just means you were smarter than some and luckier than others.
Re: Sonic Test [Re: Runnin74] #603157
02/11/10 03:35 PM
02/11/10 03:35 PM
CharlieB Offline OP
CharlieB  Offline OP
The machine shop that cleaned, magged and sonic tested the block said they can push the bore a little away from the weak side but I'm not planning on using that shop for my build. The block has not been bored yet.
Re: Sonic Test [Re: CharlieB] #603158
02/11/10 08:49 PM
02/11/10 08:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
How much did they charge for the sonic check??
Also, they usually check it in at least 2 points up and down the bore. They've only done yours in one!
For the sake of a few thou I wouldn't offset the bores.
Re: Sonic Test [Re: Stanton] #603159
02/11/10 08:57 PM
02/11/10 08:57 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The core shift is in the right direction (resulting in heavier major thrust side on 7 out of 8 cylinders)
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Sonic Test [Re: Stanton] #603160
02/11/10 09:01 PM
02/11/10 09:01 PM
CharlieB Offline OP
CharlieB  Offline OP
$189.00 for the block cleaning, magnaflux and sonic.
Re: Sonic Test [Re: CharlieB] #603161
02/11/10 09:35 PM
02/11/10 09:35 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
I think it's dependent on how much powerthe motor makes. Issue is keeping the bores round. 700+hp motors I'd want min .185. 1000hp more! You must keep that ring seal to have leakdown numbers. We loose a tenth in ET when only 1 cyl goes to 13-15.
The little old lady from Pasadena is back!
Re: Sonic Test [Re: Barnstorm] #603162
02/11/10 10:04 PM
02/11/10 10:04 PM
CharlieB Offline OP
CharlieB  Offline OP
Hoping to get in the mid-low nines in a lightened A-body- I guess around 700 hp should do it
Re: Sonic Test [Re: CharlieB] #603163
02/11/10 10:15 PM
02/11/10 10:15 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
For that kind of power you should probably try to find a block with more evenly distributed material. FWIW, I have a '230 400 block but the ultrasonic thickness gauge says it's not nearly as good as the 1974 block I ended up using. No numbers handy, sorry.
Re: Sonic Test [Re: CharlieB] #603164
02/11/10 10:17 PM
02/11/10 10:17 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I would think with the level of performance desired you would be advised to get an aftermarket block. I am sure you will hear countless people tell you that they did it with no problem, but you are asking a lot of the factory piece.
MB
Re: Sonic Test [Re: CharlieB] #603165
02/11/10 10:38 PM
02/11/10 10:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t have my sheet in front of me but when I called DLI they said my block would make a good flower pot...............10 years later and SEVERAL 7000+ rpm passes it`s still goin strong.
