Main Fuel line size #602614
02/03/10 05:37 PM
02/03/10 05:37 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
What size fuel line are you running from the fuel cell pump/filter to the regulator in the front?...
I was thinking -8AN but who runs -10AN?
This is BG 280 fuel pump by the way and needs to feed 800+hp..
Re: Main Fuel line size [Re: Bob_Coomer] #602615
02/03/10 05:47 PM
02/03/10 05:47 PM
you need to run -10an to the regulatorfrom the pump. i run a -8an back to the cell from the return.
Re: Main Fuel line size #602616
02/03/10 05:48 PM
02/03/10 05:48 PM
heres a picture of the return back to the cell.
Re: Main Fuel line size [Re: Bob_Coomer] #602617
02/03/10 05:59 PM
02/03/10 05:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use a Magnafuel 300 pump now,(street and strip car) Magnafuel wants a #10 feed to the pump from the cell, # 8 return line from the pump to the cell and a #8 to the front to the regulator I would call BG and ask them what size to use on there pump BTW, I had two of the BG280(not for street use according to BG) and sold them to freinds who have race only cars and they use 1/2(#8) aluminmum hard line to the front from there pumps
Re: Main Fuel line size [Re: Cab_Burge] #602618
02/03/10 06:03 PM
02/03/10 06:03 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I have a BG HR220 and I use a -10 suction, a -8 feed to the regulator at the carb and a -10 return. BG wants a larger return line and a generous suction line. You can hurt a pump's output more by restriction the suction.
SRT DEMON ONE SEAT
Re: Main Fuel line size [Re: Ron Silva] #602619
02/03/10 06:04 PM
02/03/10 06:04 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
2
SRT DEMON ONE SEAT
Re: Main Fuel line size [Re: Ron Silva] #602620
02/03/10 06:09 PM
02/03/10 06:09 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
-12 from the cell to the pump, then -10 to the reg, and -8 to the carb . NO problems.........
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Main Fuel line size [Re: chryco] #602621
02/03/10 06:11 PM
02/03/10 06:11 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
More .......
Feeding a 557" RBRE / KB Hemi .
Re: Main Fuel line size [Re: chryco] #602622
02/03/10 06:35 PM
02/03/10 06:35 PM
Rock Springs
Rock Springs
Im just wondering if -10 is overkill..I have a long section of -8AN hose and some fittings. I know on the dragster I ran -8AN running alky/methonal and it was what I would consider a pretty high demand system...it burnt 2 1/2 gallons of fuel per 8th mile run.
So how does one draw the line? Does duel carbs make a diff?
According to BG the 280 Pump doesnt require a return, which is fine by me. It says a -10 to from the fuel cell to the inlet of the pump, then -8 to the regulator..
I have the pump and there two port regulator, I wont be running there fuel filter..I will be running a earls 85 micron stainless mesh type filter.
http://www.barrygrant.com/bgfuel/default.aspx?page=85
Re: Main Fuel line size [Re: Bob_Coomer] #602623
02/03/10 07:10 PM
02/03/10 07:10 PM
sg66mopar Offline
sg66mopar  Offline
Lots of people claim too big of a main feed line can be detrimental. More mass of fuel and a larger cross sectional area in the line for the G forces to act on.
Everybody I know personally in SG and SC runs a -12 from the cell to pump; -10 pump to front and -8 if they have a return line. I ran a BG 280 for about 8 years at mid nines in my charger with -8 line to the front and -8 return line back to the cell. Last year I switched to the BG 400 with -12 to the pump, -10 to the front and just the short bypass from the pump to the cell. Never showed any signs of fuel starvation running 8.9 - 9.0
I did the 1 gallon gas can test on my car with no alternator, just 12.4 volts at the pump and it filled the can in about 12 seconds going through the regulators, right at the carb inlets.
Re: Main Fuel line size [Re: sg66mopar] #602624
02/03/10 07:22 PM
02/03/10 07:22 PM
MY 581 hemi has a BG 280 and i run a -10an to the pump from the cell and -8an from the pump to the regulator with no bypass but i was going to take it out and go to the -10an up to the regulator. going 9.79 now. im wondering if ill pick up with the bigger line, no sure if im starving the motor, im also going to a product engineering pump.
Re: Main Fuel line size #602625
02/03/10 07:27 PM
02/03/10 07:27 PM
this is my old setup which you might be going to.
Re: Main Fuel line size #602626
02/03/10 07:45 PM
02/03/10 07:45 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Now you guys got me thinking I can use my existing 1/2" and -8 going from the pump to the reg and just jump it to a -10 from the cell to the pump.
That would be nice.
Re: Main Fuel line size [Re: WILD BILL] #602627
02/03/10 07:58 PM
02/03/10 07:58 PM
sg66mopar Offline
sg66mopar  Offline
Do the fuel can test then you'll know. 10 second ET needs to fill the can in 25 seconds. 9 sec. need to fill the can in 20
I think you should be good to go.
Re: Main Fuel line size [Re: sg66mopar] #602628
02/03/10 08:01 PM
02/03/10 08:01 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'll definatly run that test before I shell out any I don't have anyway.
Re: Main Fuel line size [Re: sg66mopar] #602629
02/03/10 08:31 PM
02/03/10 08:31 PM
UK
602heavy Offline
602heavy  Offline
UK
9 sec et requires 180 gph , 8 sec et 240 gph , do we tend to over kill on fuel pump flow? , some guys run 400gph pumps , that's 10 sec to fill a gallon can , i realise G force comes into this but i still think it's overkill.
Re: Main Fuel line size [Re: chryco] #602630
02/03/10 09:09 PM
02/03/10 09:09 PM
springfield,il
O
orangeduster Offline
O
springfield,il
Chryco
x 2
Re: Main Fuel line size [Re: sg66mopar] #602631
02/03/10 10:03 PM
02/03/10 10:03 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
How did it flow down the course ? Did you consider g-force ? Bigger is better here too .
Food for thought.
Chryco
Re: Main Fuel line size [Re: sg66mopar] #602632
02/03/10 10:17 PM
02/03/10 10:17 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
those people are flat wrong and don't understand the mechanics of fluids. the diameter of the line has no impact on the force imparted by acceleration, the effective length of the line does. the pressure exerted on a column of fluid would be SG (specific gravity) x .433 (PSI exerted by a 12" column of water) x distance from suction to feed x G force. the actual length of the line to some extent doesn't matter. an example would be say you have 15' of hose but 5' is taken up in bends. then the effective length would be 10'. so .725 x .433 x 10' x (say 2G) = 6.28 PSI. this is the pressure the pump would have to overcome to move fluid and is part of the reason to mount the regulator at the engine. most (decent) pumps have the ability to generate a fair bit, probably upwards of 20 PSI or so. i would say the VAST majority of our cars don't pull 2G for any length of time if at all. a TF dragster pulls around 4 off the line but actually pulls harder down track.
Re: Main Fuel line size #602633
02/03/10 10:23 PM
02/03/10 10:23 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
X2
