Performer 383 Intake Manifold or Performance RPM #602327
02/03/10 04:56 AM
02/03/10 04:56 AM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
I have a 500 cu in Big block stroke with 440source heads that needs an intake manifold. In my garage, I have an Edelbrock Performer 383 intake manifold that I traded some parts for. I was thinking of using this on the stroker motor that is only going to be used for street use and would not be going over 6000 rpms.
Would my seat of the pants Dyno notice if I upgraded to something like a Performer RPM over the 383 Performer?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Performer 383 Intake Manifold or Performance RPM [Re: jrlegacy23] #602328
02/03/10 05:08 AM
02/03/10 05:08 AM
Cooperstown, NY
Cooperstown, NY
Actually, I just found an intake shootout done by Hotrod magazine. At most, its a 15hp on a little better than stock motor. I realize that the more performance oriented the motor, the more the difference in the two intakes, but I think that the difference will be that noticable on the street. here is the article:
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/edelbrock.html
Re: Performer 383 Intake Manifold or Performance RPM [Re: jrlegacy23] #602329
02/03/10 11:45 AM
02/03/10 11:45 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
nice article! was to be nice they included the test with stock manifold to get the lowest reference too. I have a performer to replace my stock unit ( I know they are virtually the same ) but will be nice to get thos comparision numbers... I should get some gain there, even small ( at the end just paid around $70 for the performer unit )
Re: Performer 383 Intake Manifold or Performance RPM [Re: NachoRT74] #602330
02/03/10 01:30 PM
02/03/10 01:30 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
So you have a 500 inch lowdeck? (400 stroker) The Performer will be a huge choke on a 500! On a 383/400 its an idle to 5500rpm unit. You have a 500 and probably a long duration cam. The RPM should be the minimum to go with.
Keep old mopars alive.
Re: Performer 383 Intake Manifold or Performance RPM [Re: jrlegacy23] #602331
02/03/10 02:21 PM
02/03/10 02:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On the part1 of the intake shootout, there wasn't much difference because the stock heads were the choke point, not the intakes. Part 2 when they used a set of CNC ported aftermarket heads showed some good difference between intakes. For your build I would use either the RPM intake or a holley street dominator.
Re: Performer 383 Intake Manifold or Performance RPM [Re: DaytonaTurbo] #602332
02/03/10 02:33 PM
02/03/10 02:33 PM
Cooperstown, NY
Cooperstown, NY
Thanks guys, I will probably go the RPM route.
Re: Performer 383 Intake Manifold or Performance RPM [Re: jrlegacy23] #602333
02/03/10 02:50 PM
02/03/10 02:50 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Honestly, you'll have Pooploads of torque with either intake on a 500" stroker.
I dropped my Perf-RPM for a tried-n-true Eddy TM7 and I still have gobs(or pooploads) of torque as well as mucho better top end.
Consider dropping on a TM6, easily bought for under $100.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Performer 383 Intake Manifold or Performance RPM [Re: Hoof Hearted] #602334
02/03/10 03:25 PM
02/03/10 03:25 PM
Cooperstown, NY
Cooperstown, NY
Thanks, I will also look into the TM6... cuz I'm a cheap b-a-stard
Re: Performer 383 Intake Manifold or Performance RPM [Re: jrlegacy23] #602335
02/03/10 07:08 PM
02/03/10 07:08 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Look into the Holley street dominator. It's a single plane. Good design and will help on the top end. Low end it's a little restrictive buy it's design. You will probably need it with the "pooploads" of torque you will deffinately have.
Re: Performer 383 Intake Manifold or Performance RPM [Re: BELVEDERE67] #602336
02/04/10 12:20 AM
02/04/10 12:20 AM
IL
71383beep Offline
71383beep  Offline
IL
Running the street dom now on my 383 and its very nice. A little less bottom end than an RPM, but much cheaper. Don't get me wrong though...the RPM is a VERY nice intake.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Performer 383 Intake Manifold or Performance RPM [Re: 71383beep] #602337
02/04/10 08:22 AM
02/04/10 08:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like the RPM and the Street Dominator. I run the Street Dominator on my 440 and my son runs the RPM on his 400 and they both work good. Ron
Re: Performer 383 Intake Manifold or Performance RPM [Re: 383man] #602338
02/04/10 11:00 AM
02/04/10 11:00 AM
Cooperstown, NY
Cooperstown, NY
Thanks guys. I have the performer 383 for sale, I am going to pick up something a little better, I think the Dominator or RPM. I did a little more research, and they seem to be more of what I am looking for.
Re: Performer 383 Intake Manifold or Performance RPM [Re: jrlegacy23] #602339
02/06/10 04:39 AM
02/06/10 04:39 AM
Cooperstown, NY
Cooperstown, NY
I just found a Torker 383 intake, looks like it may be ideal for my combo.
Re: Performer 383 Intake Manifold or Performance RPM [Re: jrlegacy23] #602340
02/06/10 03:27 PM
02/06/10 03:27 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
part 2 of that intake shootout is probably a better indicator of the the results you might achieve on a large engine than part 1. http://www.hotrod.com/techarticles/hrdp_0801_mopar_intake_manifolds/index.html time to cut the hood for a tunnel ram!
