Performer 383 Intake Manifold or Performance RPM
#602327
02/03/10 04:56 AM
02/03/10 04:56 AM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
I have a 500 cu in Big block stroke with 440source heads that needs an intake manifold. In my garage, I have an Edelbrock Performer 383 intake manifold that I traded some parts for. I was thinking of using this on the stroker motor that is only going to be used for street use and would not be going over 6000 rpms. Would my seat of the pants Dyno notice if I upgraded to something like a Performer RPM over the 383 Performer?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Performer 383 Intake Manifold or Performance RPM
[Re: jrlegacy23]
#602329
02/03/10 11:45 AM
02/03/10 11:45 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
nice article! was to be nice they included the test with stock manifold to get the lowest reference too. I have a performer to replace my stock unit ( I know they are virtually the same ) but will be nice to get thos comparision numbers... I should get some gain there, even small ( at the end just paid around $70 for the performer unit )
[Re: jrlegacy23]
#602331
02/03/10 02:21 PM
02/03/10 02:21 PM
DaytonaTurbo
Manitoba, Canada
Actually, I just found an intake shootout done by Hotrod magazine. At most, its a 15hp on a little better than stock motor. I realize that the more performance oriented the motor, the more the difference in the two intakes, but I think that the difference will be that noticable on the street. here is the article: http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/edelbrock.html
On the part1 of the intake shootout, there wasn't much difference because the stock heads were the choke point, not the intakes. Part 2 when they used a set of CNC ported aftermarket heads showed some good difference between intakes. For your build I would use either the RPM intake or a holley street dominator.
[Re: DaytonaTurbo]
#602332
02/03/10 02:33 PM
02/03/10 02:33 PM
jrlegacy23
Cooperstown, NY
Thanks guys, I will probably go the RPM route.
[Re: Hoof Hearted]
#602334
02/03/10 03:25 PM
02/03/10 03:25 PM
jrlegacy23
Cooperstown, NY
Thanks, I will also look into the TM6... cuz I'm a cheap b-a-stard
[Re: 383man]
#602338
02/04/10 11:00 AM
02/04/10 11:00 AM
jrlegacy23
Cooperstown, NY
Thanks guys. I have the performer 383 for sale, I am going to pick up something a little better, I think the Dominator or RPM. I did a little more research, and they seem to be more of what I am looking for.
[Re: jrlegacy23]
#602339
02/06/10 04:39 AM
02/06/10 04:39 AM
jrlegacy23
Cooperstown, NY
I just found a Torker 383 intake, looks like it may be ideal for my combo.
