Summit Headers #601548
02/02/10 12:57 PM
02/02/10 12:57 PM
California
Drip Offline OP
Drip  Offline OP
California
Anyone use Summit brand headers for a 440 B-body?
If so how did they work? Major clearance problems?
thanks
Re: Summit Headers [Re: Drip] #601549
02/02/10 01:28 PM
02/02/10 01:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Using them on mine. Had to a few dimples in them in a couple spots but nothing crazy. I thought they actually fit quite well for the price. Only thing I would do different is to buy remflex header gaskets to get them to seal, the copper ones I bought didn't do the trick. Also, my flange is cut between the tubes.
Re: Summit Headers [Re: DaytonaTurbo] #601550
02/02/10 04:29 PM
02/02/10 04:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
These are Summit headers. Went in pretty easy but then again I have a mini starter and the steering column was out and the motor jacked up....oh and the car was jacked up too.
Re: Summit Headers [Re: Mr.Yuck] #601551
02/02/10 05:30 PM
02/02/10 05:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used them in a buch of SBs and on my 2 4 wheel drives.Fit good and I just used the cheap gaskets that came with them.They never did leak.Got 6 years out of the last set on my plow truck and that was good for it with all the sitting and salt.Rocky
Chrysler Firepower
Re: Summit Headers [Re: therocks] #601552
02/02/10 11:55 PM
02/02/10 11:55 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
On my 440 with P/S I had to beat on #3 and #5 pretty good at the steering gear--if you do not have P/S you should be OK.
Also #7 down tube grazed the steering column coupler--had to dimple it.
And the collecter flange on the passenger side was rubbing the torsion bar. Little work with the grinder.
A fair amount of but they're in there--and the price was right!!!
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Summit Headers [Re: wingman] #601553
02/03/10 12:01 AM
02/03/10 12:01 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I just bought a pair for my 67 Satellite. I'm going to sandblast them and coat them with the summit header coating. They look just like the Headmans I took off the car. I hope they fit as good as the headmans did.
Re: Summit Headers [Re: Drip] #601554
02/03/10 12:21 AM
02/03/10 12:21 AM
NE
moparpoolman Offline
NE
I know they are higher priced but I have a set of tti's and wouldn't go any other route. My tti's went in so easy, never leaked and I left my hammer in the tool box! Plus, coated headers will last so much longer and look great too. SO, Easier to install, lasts longer, looks nicer, works better(when there's not a bunch of dents for clearance). You have to ask yourself, after you go through 2 sets of X brand headers and the work to put them in, how much are you really saving.
Re: Summit Headers [Re: moparpoolman] #601555
02/03/10 12:48 AM
02/03/10 12:48 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Actually, you'd have to go through about 7 sets to break even!
I agree, TTIs are very nice--if your budget allows.
Re: Summit Headers [Re: wingman] #601556
02/03/10 02:20 AM
02/03/10 02:20 AM
Manitoba, Canada
Manitoba, Canada
For the price and problems I've heard some guys having with TTI's, I'll stick with my summit cheapies thanks. That's a lot of money I can spend elsewhere on my car. For a nearly $600 dollar savings, I will spend a day to install a set of cheapie headers. For that price my time is worth it. That money saved will buy me a LOT of other goodies for the car, but to each his own.
Re: Summit Headers [Re: wingman] #601557
02/03/10 10:34 AM
02/03/10 10:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had PS on the car didn't have to ding anything. Going to Manual this spring. It really helps if you pull the column...and as for TTi's... well 1. they are very very expensive and 2. they are not prone to a little beating either. many people have had issues w/ them.
Best advise I can give you is TAKE YOUR TIME and don't over-tighten the bolts. I left all my ex-mani studs in!
Coming soon!!!!
Re: Summit Headers [Re: Mr.Yuck] #601558
02/03/10 01:50 PM
02/03/10 01:50 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
Just looking at that side, those look just like the Hooker Competitions I just put in my Belvedere. They went in really easy. I have a full size starter too. Speaking of the starter, I had to have help because the header and the starter had to go up simutaniously.
-1967 Belvedere II 440/4speed
Re: Summit Headers [Re: MACDiesel] #601559
02/03/10 02:19 PM
02/03/10 02:19 PM
Manitoba, Canada
Manitoba, Canada
I wouldn't want to attempt it again, but I managed to install my junkyard mini starter into my 440 with the summit headers already bolted in place. Was able to weasel the starter through the header tubes, but not easily.
