Duplicolor Engine Enamel Paint - spray can #601028
02/01/10 07:27 PM
02/01/10 07:27 PM
Williamsport, PA
Rob440Magnum Offline OP
mopar addict
mopar addict
Williamsport, PA
I just finished spray painting my aluminum intake manifold with with Duplicolor high temp engine enamel spray paint in a rattle can.
Is there a way to get this to look more glossy? What if I spray paint with high-temp clear coat by Duplicolor will that add any more shine or gloss?
Thanks, Rob
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601029
02/01/10 08:14 PM
02/01/10 08:14 PM
I'm going to go out on a limb & say yes. I was thinking on here the other day a person had a problem w duplicolor and I think he ended up clear coating it to improve it.
Re: Duplicolor Engine Enamel Paint - spray can [Re: RapidRobert] #601030
02/01/10 08:54 PM
02/01/10 08:54 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I did one for a customer of mine,it looked pretty nice.
Re: Duplicolor Engine Enamel Paint - spray can [Re: Dunnuck Racing] #601031
02/01/10 10:51 PM
02/01/10 10:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They're supplying a product to duplicate the factory finish - which wasn't glossy. Other than "custom" colors I've not seen engine enamels that produce a gloss finish.
It could also be the conditions you're spraying in. If its too cold you won't get a shine and if its too hot the paint will dry too quickly. If you're fogging it on instead of laying on enough to be "wet" you won't get a gloss either.
Re: Duplicolor Engine Enamel Paint - spray can [Re: Stanton] #601032
02/02/10 03:44 AM
02/02/10 03:44 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I hear the plastikote stuff is glossier than the duplicolor stuff. I didn't mind the lack of gloss so much as the duplicolor hemi orange is such a low solids paint it takes 80,000 coats to cover.
Re: Duplicolor Engine Enamel Paint - spray can [Re: DaytonaTurbo] #601033
02/02/10 04:00 AM
02/02/10 04:00 AM
North Las Vegas
chewy Offline
chewy  Offline
North Las Vegas
The Hi-Temp Clear yellows with heat. I tried an aluminum intake that I polished up all nice and shiny. 1000 miles later and a few runs down the track it was a pretty goldish color.
Re: Duplicolor Engine Enamel Paint - spray can [Re: chewy] #601034
02/02/10 02:00 PM
02/02/10 02:00 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
All of the Duplicolor clears yellow quickly, even their clear wheel finish, a couple of years after that it will crumble and fall off .And the Duplicolor engine enamels I used on my engine the first time were peeling everywhere within 2 years. Just got done stripping everything back down and went with Plastikote this time on advice of others here...
Re: Duplicolor Engine Enamel Paint - spray can [Re: donbarnes] #601035
02/02/10 02:06 PM
02/02/10 02:06 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i noticed the duplicolor chips so easy, what is plasticoats # for hemi orange
Re: Duplicolor Engine Enamel Paint - spray can [Re: ademon] #601036
02/02/10 03:30 PM
02/02/10 03:30 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I used Plasti-kote Chrysler Orange Part Number 226. I like the color. Been on now for 3 years, like I painted it yesterday.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Duplicolor Engine Enamel Paint - spray can [Re: ademon] #601037
02/02/10 07:17 PM
02/02/10 07:17 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I found that gasoline will strip it faster than speedy gonsalez!
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601038
02/02/10 08:13 PM
02/02/10 08:13 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
To answer the OP..I'd go over the Dupli color with Plasti Kote engine enamel clear.
Plasti Kote is the best engine paint in a spray bomb.
Nautilus Racing-
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601039
02/02/10 10:40 PM
02/02/10 10:40 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
Use the Plastikote. I put it on thick and it dries shiney. Must be hot though.
Re: Duplicolor Engine Enamel Paint - spray can [Re: Coronet-R/T-Rag] #601040
02/03/10 11:14 AM
02/03/10 11:14 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Anyone have experience with Mopar engine
paint, st.hemi orange?
Re: Duplicolor Engine Enamel Paint - spray can [Re: demonH1B] #601041
02/03/10 11:26 AM
02/03/10 11:26 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I don't think they offer it anymore. it was the best match to original ST Hemi orange, more of a red almost
Re: Duplicolor Engine Enamel Paint - spray can [Re: demonH1B] #601042
02/03/10 11:28 AM
02/03/10 11:28 AM
Colorwise race hemi is a much better match to the oe orange than the street hemi is.
Re: Duplicolor Engine Enamel Paint - spray can [Re: RapidRobert] #601043
02/03/10 04:29 PM
02/03/10 04:29 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Use Plasti-kote you won't be disappointed
What was I thinking....
Re: Duplicolor Engine Enamel Paint - spray can [Re: 72blubird] #601044
02/03/10 05:52 PM
02/03/10 05:52 PM
Plasti-kote here all the way!
Re: Duplicolor Engine Enamel Paint - spray can [Re: 72blubird] #601045
02/03/10 06:02 PM
02/03/10 06:02 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
Plasti-kote is wonderful! Recently I tried Dupli-Color's Street Hemi orange and it was the most god-awful paint I have ever used. Really sucks! As for clearcoats, I got away from the spraybomb clears and use regular automotive clear on everything. It withstands the heat and holds a beautiful shine way longer than the spraybomb clears ever could. Thought to ponder: as long as a paint comes in a spraybomb, it doesn't have hardener. Regular auto clear applied with a gun uses a hardening catalyst to enhance durability and hold a gloss.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Duplicolor Engine Enamel Paint - spray can [Re: maundmotorworks] #601046
02/04/10 07:59 PM
02/04/10 07:59 PM
Williamsport, PA
mopar addict
mopar addict
Williamsport, PA
Ok, thanks for the responses. My intake is already painted with duplicolor in Chrysler Orange about 5 days ago.
Question:
What prep work should I do to spray with plastikote clear to enhance gloss and shine?
Should I scuff with a scotchbrite, should a spray a coat or two of color by plastikote before I clear? Suggestions?
Thanks, Rob
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601047
02/04/10 08:34 PM
02/04/10 08:34 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
1 week old rattle can paint that hasn't even been heat-cured yet? Clear it. You'll get a good bond. That paint is still fresh enough.
