Holley lean condition #60090
05/20/08 09:09 AM
05/20/08 09:09 AM
Anonymous OP
Anonymous OP
could a lean condition cause a car to run a little hotter than normal??
Re: Holley lean condition #60091
05/20/08 09:09 AM
05/20/08 09:09 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
yes - too lean leads to holes in pistons.
Re: Holley lean condition [Re: MoparforLife] #60092
05/20/08 09:12 AM
05/20/08 09:12 AM
Anonymous OP
Anonymous OP
thats what I thought, thanks.
Re: Holley lean condition #60093
05/22/08 09:25 AM
05/22/08 09:25 AM
Anonymous OP
Anonymous OP
went from 70's to 76's where do I stop? this thing acts like it could take even more.
Re: Holley lean condition #60094
05/22/08 09:54 AM
05/22/08 09:54 AM
Anonymous OP
Anonymous OP
what size holley? 750 VS?
Re: Holley lean condition #60095
05/22/08 10:13 AM
05/22/08 10:13 AM
Anonymous OP
Anonymous OP
750 3310 vac sec.
Re: Holley lean condition #60096
05/22/08 02:05 PM
05/22/08 02:05 PM
Anonymous OP
Anonymous OP
Re: Holley lean condition #60097
05/22/08 03:42 PM
05/22/08 03:42 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
750 3310 vac sec.
give us some more info and we all be able to tell you whether you are in the ballpark or not.
Re: Holley lean condition [Re: Viol8r] #60098
05/22/08 04:33 PM
05/22/08 04:33 PM
Anonymous OP
Anonymous OP
69 roadrunner 383, 284/484, performer rpm, 1 3/4" headers, automatic, 3000 stall, 355 gears, 2 1/2" exhaust.
Re: Holley lean condition #60099
05/22/08 04:45 PM
05/22/08 04:45 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
at idle stick a pionty toothpick over one of the idle bleeds. find the one that drops...its lean..
is that the old tyme crap you want to hear?
Re: Holley lean condition [Re: mark7171] #60100
05/22/08 04:47 PM
05/22/08 04:47 PM
Anonymous OP
Anonymous OP
ummm no, just asking at what point will i know its jetted right. thanks for the smart a$$ reply though.
Re: Holley lean condition #60101
05/22/08 07:21 PM
05/22/08 07:21 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Stock jets are 72 in a 3310, I will say at cruise you should not need more than 74 to cure a lean condition.
Make sure your floats are not too low, that can cause a slight lean condition at cruise. There are also other factors like timing. Are you running vacuum advance? If so, with that combo it is not needed. An initial of 17 or 18 and total of 36 should be a good start.
Re: Holley lean condition #60102
05/22/08 07:43 PM
05/22/08 07:43 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Is the car exhibiting any other symptoms of lean other than running hot??????????????
Re: Holley lean condition [Re: Pacnorthcuda] #60103
05/23/08 09:27 AM
05/23/08 09:27 AM
Anonymous OP
Anonymous OP
no vacuum advance, initial timing is 15 total 34, the car screams but the tail pipes were light gray same as the plugs and the center header tubes were glowing. I have since put the 76's in it and it seems to be alot better but I dont know if it could take more or needs more. The car still runs warmer than I think it should.
Re: Holley lean condition #60104
05/23/08 09:52 AM
05/23/08 09:52 AM
Anonymous OP
Anonymous OP
just my sounds like you need a larger carb. will be alot easier to dial in. whats the rest of your
engine specs? mabey i can get a better idea.
Re: Holley lean condition #60105
05/23/08 03:08 PM
05/23/08 03:08 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
I run a 80508 750 w/ VS on my car with stock jetting (same as 3310)...no problems. Cams are pretty similar and I have a 440+0.60 over. Timing is set about the same with no vacuum advance. Runs about 190 cruising on hot days.
Re: Holley lean condition [Re: dwbiggs] #60106
05/23/08 03:13 PM
05/23/08 03:13 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I know this in going to open a can a worms because there are many theories on this but make sure you have a restrictor or a thermostat in there. If you can hold the water in the radiator just a bit longer to cool, it may just make that bit a difference you need.
Re: Holley lean condition #60107
05/23/08 03:24 PM
05/23/08 03:24 PM
I don't think your temperature (which you don't say HOW hot) is Carb related. I too ran a 750 VS Holley on a 440, with the 474/474 280 MP cam, stock jetting, headers, ran fine! (I did play with the secondary springs but that was it)
If your tubes are glowing after fast idle while the hood is up...SO do mine! And this is on a 440 850 Holley DP that is overjetted (84's , 80's are stock)
Re: Holley lean condition [Re: dwbiggs] #60108
05/23/08 05:05 PM
05/23/08 05:05 PM
Anonymous OP
Anonymous OP
yah i'll admit that i may of jumped the gun by saying that he's runnin
to small a carb. BUT unless one of the fuel passages is clogged,
or he didn't read his plugs properly, going up that many jet sizes
dictates a larger carb is needed. i HATE inter-tuning
