Re: 440 oil pan ???
[Re: Drip]
#600587
02/01/10 04:44 PM
02/01/10 04:44 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
The pan for a '69 B-body should be a "402" based on the 440Source oil pan page. Scroll half way down the page to see pics and applications for the different factory pans, along with an application table at the bottom. You can get the year of the junker New Yorker and then you will know what you're working with compared to the 402.
Re: 440 oil pan ???
[Re: badblack68]
#600592
02/02/10 01:46 AM
02/02/10 01:46 AM
Posts: 1,456 Northern CA
streetkit
Northern CA
Don't wrecking yards like Pick n Pull usually punch a hole in the pans to drain out the oil? All the pans I have seen there, have been that way.
1973 Dodge D100
