440 oil pan ??? #600582
02/01/10 12:38 PM
02/01/10 12:38 PM
California
Drip Offline OP
Drip  Offline OP
California
I need to replace my oil pan and pick up. Pulled a 440 out of a motorhome for my 69 B-body. Are all BB oil pans the same for cars? Can I use a pan off a Fury or New yorker? Of do i need one for a B-body.
Re: 440 oil pan ??? [Re: Drip] #600583
02/01/10 12:43 PM
02/01/10 12:43 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
Whats the number stamped in the bottom of it?
Re: 440 oil pan ??? [Re: CYACOP] #600584
02/01/10 01:47 PM
02/01/10 01:47 PM
California
Drip Offline OP
Drip  Offline OP
California
not sure of the number of the one in the new yorker. There is a new yorker at the local pick and pull and i was going to pull the pan off it and use it if I can. What is the number I am looking for.
Re: 440 oil pan ??? [Re: Drip] #600585
02/01/10 02:06 PM
02/01/10 02:06 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
As long as it is a center sump pan you should be okay. It may have the number 402 on the bottom of the pan but maybe not.
Re: 440 oil pan ??? [Re: Mopar Grandpa] #600586
02/01/10 02:54 PM
02/01/10 02:54 PM
SW Fla.
SW Fla.
As said, a 402 will work, it has the windage tray in it but I used a 669 out of a 72 C body that worked in my 72 B body.
Re: 440 oil pan ??? [Re: Drip] #600587
02/01/10 04:44 PM
02/01/10 04:44 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
The pan for a '69 B-body should be a "402" based on the 440Source oil pan page. Scroll half way down the page to see pics and applications for the different factory pans, along with an application table at the bottom. You can get the year of the junker New Yorker and then you will know what you're working with compared to the 402.
Re: 440 oil pan ??? [Re: Drip] #600588
02/01/10 04:55 PM
02/01/10 04:55 PM
That'll work and might consider welding in a baffle around the perimeter of the sump which if so you'd want to do before you paint it and that'd give you a high perf pan right from the start.
Re: 440 oil pan ??? [Re: RapidRobert] #600589
02/01/10 06:14 PM
02/01/10 06:14 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Guy on ebay selling brand new 402 pans. I got one. Very nice item heavy gauge steel. Got the windage tray from summit.
Re: 440 oil pan ??? [Re: RapidRobert] #600590
02/01/10 06:53 PM
02/01/10 06:53 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Depending on the year of the New Yorker, if it's a '699' pan it'll probably have a baffle already.
Re: 440 oil pan ??? [Re: 440newport] #600591
02/01/10 08:15 PM
02/01/10 08:15 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I've got 10 new 402 oil pans in stock and ready to ship.
Re: 440 oil pan ??? [Re: badblack68] #600592
02/02/10 01:46 AM
02/02/10 01:46 AM
Northern CA
streetkit Offline
streetkit  Offline
Northern CA
Don't wrecking yards like Pick n Pull usually punch a hole in the pans to drain out the oil? All the pans I have seen there, have been that way.
1973 Dodge D100
