70 Cuda gas tank sending unit #59868
05/19/08 08:03 PM
05/19/08 08:03 PM
Harrisburg, Pa.
screamindriver Offline OP
Harrisburg, Pa.
Hi guys... Anyone have the original part number for a 440-6 fuel tank sending unit ???? {3/8 line with return}...
Re: 70 Cuda gas tank sending unit [Re: screamindriver] #59869
05/19/08 09:07 PM
05/19/08 09:07 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
3420845
Amazing how an unchallenged lie can become the absolute truth.
Re: 70 Cuda gas tank sending unit [Re: beepbeep] #59870
05/20/08 01:23 PM
05/20/08 01:23 PM
Harrisburg, Pa.
Harrisburg, Pa.
Thanks Beepbeep !!! ...I could'nt find any documentation with that peticular part number for what I was contemplating.. ....Which is......... A while back we were involved with a thread on some small detail items and you posted a pic of an original paper tag on a sending unit... I was wondering if you or anyone has any info on the use of this tag...Have you ever run across any more ???Basically, was it a widely used paper tag that eventually {and probably quickly} fell off ???? I was going to make one up for a cool detail item... Any thoughts are apreciated...
Re: 70 Cuda gas tank sending unit [Re: screamindriver] #59871
05/20/08 02:46 PM
05/20/08 02:46 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Colin
It appears that two different SO/tag part numbers were used on E Bodys. The one pictured above for the 5/16" sender and another for the 3/8" sender. Never have investigated any further to find out what parts made up the number.
Re: 70 Cuda gas tank sending unit [Re: beepbeep] #59872
05/20/08 06:33 PM
05/20/08 06:33 PM
Harrisburg, Pa.
Harrisburg, Pa.
Considering what the tag is made of and it's location I'm amazed you found one in such good condition...It's a great reference example... Thanks again for sharing all the great detail items and info you've found...
Re: 70 Cuda gas tank sending unit [Re: screamindriver] #59873
05/21/08 02:25 PM
05/21/08 02:25 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
The p/n for the 3/8" E Body is 3404550. Dave at ECS has made some up.
Re: 70 Cuda gas tank sending unit [Re: beepbeep] #59874
05/21/08 05:59 PM
05/21/08 05:59 PM
Harrisburg, Pa.
Harrisburg, Pa.
Thanks for the update.. . I was going through the different fonts last night with the program I was going to use for the tag and it'll be much easier to just make the call...I'm very pleased with everything I've snagged from Dave in the past...
