W2, W5 Rocker options #598395
01/30/10 02:42 PM
01/30/10 02:42 PM
Manitoba, Canada
O
Overdrive440 Offline OP
O
Manitoba, Canada
I have a set of bare W5's and am wondering what my current options are for rocker gear. I would like a durable setup, as I'm building the engine for street use and auto-x, with once or twice per year drag racing thrown in for fun.
Re: W2, W5 Rocker options [Re: Overdrive440] #598396
01/30/10 03:18 PM
01/30/10 03:18 PM
oregon
greendart408 Offline
oregon
I run harland sharpe on my w5 motor. Simple and work great
Re: W2, W5 Rocker options [Re: greendart408] #598397
01/30/10 03:24 PM
01/30/10 03:24 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
on my w5's i was using the erson rockers, good luck finding a set! t/d is a very good option, jesel too but at a higher price.. im using t/d on my indys....
Re: W2, W5 Rocker options [Re: SB449VALIANT] #598398
01/30/10 03:42 PM
01/30/10 03:42 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
Erson's would be my choice. I've had them and HS's. Ersons'simply have more material at the arch adjacent the spring, as a result of a smaller shaft. But they may be impossible to find. T&D would be my choice if big pressures are expected.
Damn! I dropped my change.............
Re: W2, W5 Rocker options [Re: lenweiler] #598399
01/30/10 04:21 PM
01/30/10 04:21 PM
Manitoba, Canada
O
O
Manitoba, Canada
I guess I should have bought a set of Ersons two years ago when I first heard about them. They aren't listed in the PBM-Erson catalog anymore.
I keep hearing about Norris rockers, but I can't find any info, or even if they are still available.
Re: W2, W5 Rocker options [Re: Overdrive440] #598400
01/30/10 08:44 PM
01/30/10 08:44 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Get Harland Sharps and don't worry about it. There was a design problem with the Erson's, they're no longer made and therefore spares are non-existent unless you find someone with a broken set. The Harlands will hold up to anything it sounds like you will throw at them.
Re: W2, W5 Rocker options [Re: Blucuda413] #598401
01/30/10 08:59 PM
01/30/10 08:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....care to explain?
We run the Ersons on my dads W5's. I think when I finally got ahold of the "powers that be" that they only had two sets left. In hindsite I should have bought them both. We've had no issues with them so far.
Re: W2, W5 Rocker options [Re: Blucuda413] #598402
01/30/10 09:01 PM
01/30/10 09:01 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
So, what was Erson's design problem?
Re: W2, W5 Rocker options [Re: Overdrive440] #598403
01/30/10 09:03 PM
01/30/10 09:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
TD makes rockers for them.... all I run now days
(last 10 years) is TD... great quality .... I run
fairly high rpm and strong spring pressures and never
had a single problem with the TD's
Re: W2, W5 Rocker options [Re: dartman366] #598404
01/30/10 09:13 PM
01/30/10 09:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....if you're running 1.6's and break something, give me a shout. I'll buy your leftovers.
Re: W2, W5 Rocker options [Re: J_BODY] #598405
01/31/10 12:35 AM
01/31/10 12:35 AM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Me too I'm screwd if I break something need to have some extra parts
We got harlands on dads car and I much rather run the ersons
Re: W2, W5 Rocker options [Re: Dustedu] #598406
01/31/10 12:53 AM
01/31/10 12:53 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Norris rockers.I dont know if you can get a full set but I recently purchased some spares.They're also very good. There are some great ones listed above.
Re: W2, W5 Rocker options [Re: dartman366] #598407
01/31/10 02:01 AM
01/31/10 02:01 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The problem may have been only with the very early units. If I remember correctly the fix to the problem was to saw through one side of the hold down. I can't remember what the sympton was to require this mod. It's been a bunch of years ago. I didn't get to use mine because of lack of pv clearance(machine shop calc goof) so I sold them and went to the Harland Sharpes. They were very nice rockers and it upset me that I could not use them.
Re: W2, W5 Rocker options [Re: Blucuda413] #598408
01/31/10 10:00 AM
01/31/10 10:00 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Do yourself a favor and buy Harland Sharp, T&D or Jesel. We had failures in two 1.6 Ersons and couldn't get replacements so I had to sell them as a partial set and buy the HS's for $1000.
Go with a company that has been in business for many years and will likely survive in this economy.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: W2, W5 Rocker options [Re: Plumb Wired] #598409
01/31/10 04:02 PM
01/31/10 04:02 PM
Manitoba, Canada
O
O
Manitoba, Canada
Jesel lists them for use with 48* lifter angles... but they seem to be much more $ than the T&D or Harland Sharps. I'm leaning towards the T&D.
Re: W2, W5 Rocker options [Re: Overdrive440] #598410
01/31/10 07:51 PM
01/31/10 07:51 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
I just got a set of W5s with the TD rocker setup - it is a very sweet setup and appears very durable. Each pair of valves has its own shaft and rockers so if you did have a failure you could replace just one rocker set.
Don't forget to plug the oil hole - neerly missed it -whew.
i can send pics if you like - send me a pm.
Re: W2, W5 Rocker options [Re: Overdrive440] #598411
02/01/10 11:15 AM
02/01/10 11:15 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I have the Jesels on my X block w5 motor. They pushrod oil. The fit is perfect and they have been super thus far( 5 years or so)
the cost me about 700 bucks as i recall.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: W2, W5 Rocker options [Re: B3422W5] #598412
02/01/11 06:32 PM
02/01/11 06:32 PM
Manitoba, Canada
O
O
Manitoba, Canada
Apparently Crane has rockers again:
Crane's web page
Re: W2, W5 Rocker options [Re: Overdrive440] #598413
02/01/11 07:13 PM
02/01/11 07:13 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
crane is good for a slant six..rockers ARE poo poo
Re: W2, W5 Rocker options [Re: fishy340] #598414
02/01/11 07:22 PM
02/01/11 07:22 PM
Manitoba, Canada
O
O
Manitoba, Canada
Guess for the money its either T&D or Jesel for my heads then.
