Re: W2, W5 Rocker options
[Re: SB449VALIANT]
#598398
01/30/10 03:42 PM
01/30/10 03:42 PM
Posts: 259 Canada
lenweiler
Canada
Erson's would be my choice. I've had them and HS's. Ersons'simply have more material at the arch adjacent the spring, as a result of a smaller shaft. But they may be impossible to find. T&D would be my choice if big pressures are expected.
Damn! I dropped my change.............
[Re: lenweiler]
#598399
01/30/10 04:21 PM
01/30/10 04:21 PM
Posts: 168 Manitoba, Canada
Overdrive440
Manitoba, Canada
I guess I should have bought a set of Ersons two years ago when I first heard about them. They aren't listed in the PBM-Erson catalog anymore. I keep hearing about Norris rockers, but I can't find any info, or even if they are still available.
[Re: Blucuda413]
#598401
01/30/10 08:59 PM
01/30/10 08:59 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
There was a design problem with the Erson's
....care to explain?
We run the Ersons on my dads W5's. I think when I finally got ahold of the "powers that be" that they only had two sets left. In hindsite I should have bought them both. We've had no issues with them so far.
[Re: Blucuda413]
#598402
01/30/10 09:01 PM
01/30/10 09:01 PM
dartman366
Mt. Vernon, Ohio
Get Harland Sharps and don't worry about it. There was a design problem with the Erson's, they're no longer made and therefore spares are non-existent unless you find someone with a broken set. The Harlands will hold up to anything it sounds like you will throw at them.
So, what was Erson's design problem?
[Re: Overdrive440]
#598403
01/30/10 09:03 PM
01/30/10 09:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
TD makes rockers for them.... all I run now days (last 10 years) is TD... great quality .... I run fairly high rpm and strong spring pressures and never had a single problem with the TD's
[Re: dartman366]
#598404
01/30/10 09:13 PM
01/30/10 09:13 PM
J_BODY
aZLiViN
.....if you're running 1.6's and break something, give me a shout. I'll buy your leftovers.
[Re: J_BODY]
#598405
01/31/10 12:35 AM
01/31/10 12:35 AM
Posts: 993 Louisville, MS
Dustedu
Louisville, MS
Me too I'm screwd if I break something need to have some extra parts We got harlands on dads car and I much rather run the ersons
[Re: Blucuda413]
#598408
01/31/10 10:00 AM
01/31/10 10:00 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Do yourself a favor and buy Harland Sharp, T&D or Jesel. We had failures in two 1.6 Ersons and couldn't get replacements so I had to sell them as a partial set and buy the HS's for $1000. Go with a company that has been in business for many years and will likely survive in this economy. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
