TTI,s and B1Ba brodix heads. #597888
01/29/10 11:37 PM
01/29/10 11:37 PM
Finally a HUSKER again
Moparnut426 Offline OP
I got my standard small block TTI headers modified today to fit my B1Ba heads. I am gonna have to make a "special" socket to use on the plugs, and I had to remove the strut between the header tubes, but They fit on the heads on the stand. Pizzes me off that there isnt a header for them out there, but What do ya do.
Kasey
Re: TTI,s and B1Ba brodix heads. [Re: Moparnut426] #597889
12/21/10 02:21 PM
12/21/10 02:21 PM
oklahoma
jaye73 Offline
jaye73  Offline
oklahoma
If your still out there i have some ?'s about your mods you made.
Re: TTI,s and B1Ba brodix heads. [Re: Moparnut426] #597890
12/21/10 03:10 PM
12/21/10 03:10 PM
You have a PM
Re: TTI,s and B1Ba brodix heads. [Re: Moparnut426] #597891
12/21/10 08:20 PM
12/21/10 08:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I thought you got rid of those for the indybrocks our did I get that wrong
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: TTI,s and B1Ba brodix heads. [Re: dusturbd340W5] #597892
12/21/10 09:00 PM
12/21/10 09:00 PM
Yep, I did, this is an old post, he just asked me how I got things to fit. I told him in a PM the entire PAIN IN THE BUT they were. Quick 77 R/T has them now, and I believe he is going to switch to an offset rocker shaft, and stand set up to clear the rocker issues, and he is dealing with the headers in his own way.
Re: TTI,s and B1Ba brodix heads. [Re: Moparnut426] #597893
12/21/10 09:01 PM
12/21/10 09:01 PM
Kissimmee Fl.
Kissimmee Fl.
I guess I should look at the dates
Re: TTI,s and B1Ba brodix heads. [Re: dusturbd340W5] #597894
12/22/10 01:30 AM
12/22/10 01:30 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
YEAH ITS OLD, BUT WHO CARES, LETS BRING IT BACK.....
here is my b1ba´s with custom header.
Re: TTI,s and B1Ba brodix heads. [Re: SB449VALIANT] #597895
12/22/10 01:31 AM
12/22/10 01:31 AM
Mcallen, TX
Mcallen, TX
2
Re: TTI,s and B1Ba brodix heads. [Re: SB449VALIANT] #597896
12/22/10 01:32 AM
12/22/10 01:32 AM
Mcallen, TX
Mcallen, TX
3
Re: TTI,s and B1Ba brodix heads. [Re: SB449VALIANT] #597897
12/22/10 01:41 AM
12/22/10 01:41 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Ive no worries on headers, with the alterktion front end I can run almost any off the shelf header part or build a set. Ive some 2 inch hooker super comps that will work.
Other then a few valve train geometery issues, still a easy fix....Im pretty happy.
Re: TTI,s and B1Ba brodix heads. [Re: quick77rt ] #597898
12/22/10 08:33 AM
12/22/10 08:33 AM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
Just to add, mine were ordered with the exhaust blank, and drilled to accept headers without flanges. Yes, they also needed a couple of tubes altered to clear the block, but they fit fine. Heddman brand.
Re: TTI,s and B1Ba brodix heads. [Re: SB449VALIANT] #597899
12/22/10 12:49 PM
12/22/10 12:49 PM
oklahoma
jaye73 Offline
jaye73  Offline
oklahoma
I'm the guy that's Been talking with moparnut about the headers. What flange did u end up using on your? Is you block a R or La, just trying to figure out how you Got the 449ci. Thanks and I'm glad I finely found someone else that's running these heads! I have been seaching for 2 weeks.
Re: TTI,s and B1Ba brodix heads. [Re: jaye73] #597900
12/22/10 02:31 PM
12/22/10 02:31 PM
Mine is a 408, The block is a 72 360 block, the flange on mine are W2/W5 TTI.
Kasey
Re: TTI,s and B1Ba brodix heads. [Re: Moparnut426] #597901
12/22/10 03:00 PM
12/22/10 03:00 PM
Mcallen, TX
Mcallen, TX
I used to have that set of B1´s, not anymore. Almost nobody likes them or use them. Engine was an 418ci. That was an x block...etc best et with that unported set was 10.50 at about 129.
Now on the 449 is a difrent story, right now the valiant is at the shop, custom headers and a few other things needs to be done. Gilberto
P.S. Those flanges came from tti, p.n. TTIFLG-340w2 for the b1`s. and also used the TTIFLG-340w5 for my set of w5´s, about $44.00 a set, at mancinis.
Re: TTI,s and B1Ba brodix heads. [Re: SB449VALIANT] #597902
12/22/10 03:16 PM
12/22/10 03:16 PM
Mcallen, TX
Mcallen, TX
i also used an x block for the 449, with a 4.250 Magnum Callies,GRP 1200 rods, Diamond 14.2:1pistons. Indy´s rp 245 etc, Thanks for asking. gilberto
Re: TTI,s and B1Ba brodix heads. [Re: SB449VALIANT] #597903
12/22/10 07:45 PM
12/22/10 07:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I used to think those b1ba heads were not a decent piece also...but after a local guy around here went 9.07 with them at 148, in granted a 2500 pound tube chassis cuda, i became a believer that they can produce fairly good power if the combo is right.
that cuda ran a 904 and no power adders, btw
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: TTI,s and B1Ba brodix heads. [Re: B3422W5] #597904
12/22/10 09:25 PM
12/22/10 09:25 PM
oklahoma
jaye73 Offline
jaye73  Offline
oklahoma
I tell you, yall have been the most help i have had in weeks and can't thank yall enough. I think from all the frustating things i have herd about the exhaust, I think i will just spend the extra money and have a custom set made. thanks again and Happy Holidays!!!!!
Re: TTI,s and B1Ba brodix heads. [Re: jaye73] #597905
12/22/10 09:27 PM
12/22/10 09:27 PM
Merry christmas to you too, and
CUSTOME HEADERS IS THE ONLY way to go!!! You will have a good set up.
Kasey
Re: TTI,s and B1Ba brodix heads. [Re: Moparnut426] #597906
12/22/10 10:07 PM
12/22/10 10:07 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Great, I got heads no one wants or like...
Re: TTI,s and B1Ba brodix heads. [Re: quick77rt ] #597907
12/22/10 10:29 PM
12/22/10 10:29 PM
I liked them, I just hated the headaches I was having W them. The heads you got will make ore power for your combo for sure.
Kasey
