Page 2 of 3 1 2 3
Re: Gotta little more done [Re: roadhazard] #597796
01/30/10 11:34 AM
01/30/10 11:34 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
10.60's
Re: Gotta little more done [Re: wheelsup68dart] #597797
01/30/10 11:49 AM
01/30/10 11:49 AM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
10.60's
ON the other hand, knowing my luck
Re: Gotta little more done [Re: WILD BILL] #597798
01/30/10 11:52 AM
01/30/10 11:52 AM
Columbus, Ohio
Columbus, Ohio
Bill, you should pack things up and come down toward Columbus to go to Mike DeChicos cancer benefit practice tree race this afternoon.
Re: Gotta little more done [Re: wheelsup68dart] #597799
01/30/10 11:55 AM
01/30/10 11:55 AM
BROOK PARK, OH
BROOK PARK, OH
I'm working
Re: Gotta little more done [Re: WILD BILL] #597800
01/30/10 08:58 PM
01/30/10 08:58 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Does that paint stay one pretty good? I wanted to paint the inside of mine, but was concerned that it would come off and clod up oil pick up or mess up oil pump.
What about out side? Just paint or primer first?
Brian
Re: Gotta little more done [Re: WILD BILL] #597801
01/30/10 09:04 PM
01/30/10 09:04 PM
Scott's hoping for 700+ HP. I really don't know what to expect and am trying to remain realistic.
The paint was Rustoleum rust metal primer and it's purpose is to speed up oil return as well as seal the metal and seal in any residule casting sand that may still be there.
Car weighs 2820 W/o me and 2960 on the line. Might be a little less now with some parts on this build being lighter than what I was running.
Wild bIll, 1st you should of painted the inside Blue!
2nd,your telling me you weigh 140 lbs.
Jesus, i weighed that as a freshman in High School.
Re: Gotta little more done #597802
01/30/10 09:19 PM
01/30/10 09:19 PM
BROOK PARK, OH
BROOK PARK, OH
No I hit the wrong dam key. I weigh around 160 so it should read 2980
I'm sure the paint will hold up fine inside the block.
Re: Gotta little more done [Re: WILD BILL] #597803
01/30/10 09:23 PM
01/30/10 09:23 PM
Mooresburg, Tn
Mooresburg, Tn
Are you going to also put paint on the inside, or leave it primer?
Re: Gotta little more done [Re: '72CudaRacer] #597804
01/30/10 09:27 PM
01/30/10 09:27 PM
BROOK PARK, OH
BROOK PARK, OH
I'm sure I'll find out next Thur when I can get back out there
I did pick up the paint for the outside of the block though
Re: Gotta little more done [Re: WILD BILL] #597805
01/30/10 09:44 PM
01/30/10 09:44 PM
USA
Lawn Monkey Offline
Lawn Monkey  Offline
USA
Wild Bill I have two 50 year old Farm All tractors they painted the inner block at the factory and not one speck of paint has flaked off either one,,, just thought I'd throw that in there..... I do like your idea
Re: Gotta little more done [Re: Lawn Monkey] #597806
01/30/10 09:58 PM
01/30/10 09:58 PM
BROOK PARK, OH
BROOK PARK, OH
It wasn't my idea. Scott does it to all the race motors he builds.
Re: Gotta little more done [Re: WILD BILL] #597807
01/30/10 09:59 PM
01/30/10 09:59 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
scott just wants the primer inside.
Re: Gotta little more done [Re: blownzoom440] #597808
01/30/10 10:49 PM
01/30/10 10:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Bill,your car is about 1000 lbs lighter than my junk
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Gotta little more done [Re: hemi-itis] #597809
01/30/10 11:13 PM
01/30/10 11:13 PM
Looks real nice Bill Are you guys going back with the same rotating assembly or something with some more stroke? poppaj
Re: Gotta little more done #597810
01/30/10 11:30 PM
01/30/10 11:30 PM
BROOK PARK, OH
BROOK PARK, OH
Most of last years motor is not being used. We are using the block and forged crank that I had in my garage.
It is a factory forged crank though so no stroker.
Pistons are from Weisco's Pro Tru line and the rods are K1 H beams. My old motor had Hyper pistons and LY rods W/ a cast crank.
Re: Gotta little more done [Re: hemi-itis] #597811
01/30/10 11:32 PM
01/30/10 11:32 PM
BROOK PARK, OH
BROOK PARK, OH
Start then
Re: Gotta little more done [Re: WILD BILL] #597812
01/31/10 12:30 AM
01/31/10 12:30 AM
tboomer Offline
tboomer  Offline
Bill...Did you go with flat tops or domes...Did ya pick a cam yet??
Re: Gotta little more done [Re: tboomer] #597813
01/31/10 12:46 AM
01/31/10 12:46 AM
BROOK PARK, OH
BROOK PARK, OH
Flat tops
The plan was to use to use my 555 solid flat tapet cam.
Then again not much of the original plan is holding true so
Re: Gotta little more done [Re: WILD BILL] #597814
01/31/10 12:48 AM
01/31/10 12:48 AM
Columbus, Ohio
Columbus, Ohio
You got some flow now out of the heads, scrap that street cam and get some wind in there. Just let Scott do his thing and let you write the checks. BTW who is building a trans to hold up to the new power level.
Re: Gotta little more done [Re: wheelsup68dart] #597815
01/31/10 12:52 AM
01/31/10 12:52 AM
BROOK PARK, OH
BROOK PARK, OH
Page 2 of 3 1 2 3
