Gotta little more done
#597776
01/29/10 09:47 PM
01/29/10 09:47 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I finally got back out to Scott's and got a little more done.
Firt step was to measure the piston depth so we knew how much to cut. I was a little surprised that they were fairly close all around. RH side was .0435 in the out board cylinders while the LH was .039 and .0415. For some reason I expected it have more of a varience.
Well it has no varience now. The deck was cut to give an .010 depth Alot better than my previous .102 in the hole
I also got the inside of the block painted. Surprisingly didn't get much on me though
While I painting Scott started working on the heads.
OOTB flow was 269 @ 800 on a supre flow bench
Flowed after getting worked they went to 306 @ 800. I think he said they were at 298 at 600 and 700. Maybe he should chime in with the all the flow data in case my memory is shot
Some comparison shots
Inside of the block all painted. Now for some color on the outside
Re: Gotta little more done
[Re: DoubleD]
#597780
01/29/10 10:30 PM
01/29/10 10:30 PM
WILD BILL
BROOK PARK, OH
are those the B1-BS heads?
Might be on the work bench but mine are Eddy RPM.
[Re: blownzoom440]
#597783
01/29/10 11:20 PM
01/29/10 11:20 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Bill, What HP are you looking at when the motor is done... What is the weight of your car ....
[Re: WILD BILL]
#597795
01/30/10 11:16 AM
01/30/10 11:16 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Bill you are a real artist with that brush I'll give you a call to paint mine on the next go around You'll like having a painted block. It makes clean up a lot easier. Should make some good power with a little wind in it
