A-Body headliner with windows in? #59772
05/19/08 03:32 PM
05/19/08 03:32 PM
Indiana
W5Duster436 Offline OP
Indiana
I believe that the teeth are on the inside but does the front/rear windows need to be out to install the headliner?
Logistics are killing me to get the headliner installed since the car is inoperable. I am trying to see if I can get it running first then install both front/rear glass and have the headliner installed. Any problems with this?
Re: A-Body headliner with windows in? [Re: W5Duster436] #59773
05/19/08 04:16 PM
05/19/08 04:16 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Yes, it can be done with the front and rear glass in. It's a matter of getting the edges under the window gasket which isn't a big deal. However, having done it with the glass out, I'd say it makes the job a lot easier.
Re: A-Body headliner with windows in? [Re: W5Duster436] #59774
05/19/08 04:42 PM
05/19/08 04:42 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I did mine this last winter with all the windows in.
No big deal. It is a couple hour job though. Make
sure you have the side clips to hold it in place
while the adhesive is drying.
Re: A-Body headliner with windows in? [Re: Dart 340] #59775
05/19/08 04:46 PM
05/19/08 04:46 PM
Kirkland, Washington
Pacnorthcuda Offline
I did mine on a 70 Cuda, all glass in. Buy a few boxes of the little black office-supply clips. In addition to the stock clips that stay on the car. Clips are your friend. I did the front, let glue dry, did the rear, let glue dry, one side, dry, last side. Results are perfect. But it took time.
Re: A-Body headliner with windows in? [Re: Pacnorthcuda] #59776
05/19/08 07:00 PM
05/19/08 07:00 PM
Indiana
Indiana
I just don't have the patience to try putting one in. For 100 bucks someone else can do it. I just wanted to make sure that he could still do it if I put the glass in. Wish I could just find someone that would come to my house and do it. Would make things MUCH easier.
I think I have about 10 of those little black clips. They are about 3/8" in wide and a c-clip type thing? Had to dig them outta the bags and I believe that's where they go.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: A-Body headliner with windows in? [Re: 70Duster440] #59777
05/20/08 04:16 PM
05/20/08 04:16 PM
Bellevue WA
360ChallengerB3 Offline
Bellevue WA
Make sure you have had a tetanus shot recently.
