Misc. "roller cam on the street" tech questions #597575
01/29/10 06:15 PM
01/29/10 06:15 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Figure these questions would be w/ a "moderate" .650"-ish roller cam.
Are Comp 943 springs durable enough for street use? Not like a "daily driver", but running up say 2000 miles a year on the street/strip.
Have those of you running roller cams seen any real wear and / or quality differences in the various brands of bronze distributor gears? There seems to be a pretty wide range of prices and I'm not sure what you get for the extra $$$.
"Affordable" lifters of choice? Are the Comp 829 solid-body lifters still a good option, or are their other brands NOT costing twice as much that are worth considering? This could be in either an unbushed block OR a block that's been bushed but doesn't have any oil feed holes in the lifter bore bushings.
What's the simplest & most cost-effective method for setting the cam's end play? I see different types of cam buttons offered, but don't know which ones are more likely to have durability issues in this sort of application.
Re: Misc. "roller cam on the street" tech questions [Re: BradH] #597576
01/29/10 06:24 PM
01/29/10 06:24 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
600lb springs, comp lifters should be ok. Crane lifters are no longer around, so Crower lifters are the best lifters under $1000.
I have not had any problems using Milodon bronze gears. I drive 7000+ miles a year and haven't had one go bad, yet
As for a cam button, I have only used gear drives with roller cams on Mopars, but make sure you get a strong cover like Indy, AndyF, etc to handle the button.
I don't know about the springs. someone else will have to help you with that.
Re: Misc. "roller cam on the street" tech questions [Re: BradH] #597577
01/29/10 06:26 PM
01/29/10 06:26 PM
tboomer Offline
tboomer  Offline
Good questions,Brad! I am looking for a roller in the .600 to .625 range...I have heard of good luck with Herbert lifters...Who makes them??
Re: Misc. "roller cam on the street" tech questions [Re: BradH] #597578
01/29/10 06:33 PM
01/29/10 06:33 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
I use comp 829's in all my street cars.They see maybe 3,500 miles a year.I have a set in my wagon now that has 6,500 miles on them no problems.I have a ton of spring on the car too.Idle time is what kills the springs.
I have seen no difference in the dist gears.All seem to be good.
I have only bushed one block in my life.It was a Hemi that I had a ton of money in.I think it is a waste.I've done maybe 30 that ain't bushed NEVER a problem.
Just use the cheap nylon button.
Re: Misc. "roller cam on the street" tech questions [Re: 8secDart] #597579
01/29/10 08:24 PM
01/29/10 08:24 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
FWIW,
When I was trying to decide on springs for my roller, (which I dont know if I'll ever use, due to not having good rockers) I searched around and was told Isky springs seem to last longer than Comps. Dwayne also said he likes Iskys over Comps. I found a set of dyno time only Isky Tool Room springs on the bag. They pressured OK and are on the heads at the moment. Dont know if that really helps you.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Misc. "roller cam on the street" tech questions [Re: Von] #597580
01/29/10 08:44 PM
01/29/10 08:44 PM
Missouri
galen Offline
galen  Offline
Missouri
I am running the 943 comp springs and have 600 miles on them so far at .700 lift. Just had my Indy heads machined for spring locators and when we checked the springs all were same as new. K-motion told me direct not to run the K-950s on the street, they will break. I have a set of 9385 Iskys I will try if the comps go down, Isky says they will hold up on the street also. I have 600 miles on Indy bronze dist gear and shaft. It shows slight amount of wear. Galen
Re: Misc. "roller cam on the street" tech questions [Re: galen] #597581
01/29/10 09:19 PM
01/29/10 09:19 PM
UK
602heavy Offline
602heavy  Offline
UK
Got 3000 street miles on comp roller lifters , 280lb on the seat with 720lb over the nose , got a fair ammount of leakage through lifter bores (not bushed) but still maintain 25lb oil pressure @ idle , i think these lifters are living due to the fact the lifter bores are'nt bushed..........prime the oil with the valley plate off & it floods the cam/lifters , just my
Re: Misc. "roller cam on the street" tech questions [Re: 602heavy] #597582
01/29/10 09:41 PM
01/29/10 09:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
my one suggestion would be, have the springs checked to make sure they are what they say they should be. someone here i know checked comp springs and they were all over the place, called comp and while on the phone they were spitting out numbers all over the place too, he actually asked "are you checking springs with the same part number" so like everything else, check it before you use it
i'm a believer in big pressures too like the others said
Re: Misc. "roller cam on the street" tech questions [Re: BradH] #597583
01/30/10 02:57 AM
01/30/10 02:57 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve been running a solid Isky roller for almost 5 years and changed springs once along w/a bronze gear both just for piece of mind. I`m on the same set of Isky solid body drop in lifters and run their rollerized cam button touching a stock timing cover............a few thousand miles later all seems well and thats w/.680-.660 lift and 275-280 degs. dur @ .050.....mileage sucks but what a blast to drive.
Re: Misc. "roller cam on the street" tech questions [Re: 8secDart] #597584
01/30/10 06:06 AM
01/30/10 06:06 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Ive researched the "bushing the block" deal for the last couple months...
99% say not necessary ( CHECK YOUR GEOMETRY) , and that includes a couple big engine places.
and... Thumper has been running that thing for a long time on the street-- theres some honest , real world info there
Re: Misc. "roller cam on the street" tech questions [Re: 493_DART] #597585
01/30/10 06:18 AM
01/30/10 06:18 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
and Ted...
you aint gonna catch me in that big OL' Dodge.... better put a roller in her....... or put a .006 light on me......
neither one of us has a transbrake i guess .....you might tree my ass
Re: Misc. "roller cam on the street" tech questions [Re: 493_DART] #597586
01/30/10 07:39 AM
01/30/10 07:39 AM
tboomer Offline
tboomer  Offline
Count on it!!
Re: Misc. "roller cam on the street" tech questions [Re: tboomer] #597587
01/30/10 07:57 AM
01/30/10 07:57 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Oh....its On now........first round TT , CF,,might need a wager...
Re: Misc. "roller cam on the street" tech questions [Re: 493_DART] #597588
01/30/10 08:55 AM
01/30/10 08:55 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I ran a comp XR286R with comp lifters / plain chrome timing cover and unbushed...
Mopar Performance
Re: Misc. "roller cam on the street" tech questions [Re: moparniac] #597589
01/30/10 11:24 AM
01/30/10 11:24 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I wouldn't run a roller without a button/bushing the valvetrain is too expensive to run the risk of chewing something up. Additionally the natural back-n-forth will wear out that bronze dizzy drive a heck of a lot quicker.
WIZE
In Car:
Re: Misc. "roller cam on the street" tech questions [Re: 8secDart] #597590
01/30/10 11:59 AM
01/30/10 11:59 AM
NC
440Jim Offline
440Jim  Offline
NC
How much is a "ton"? 200/600 or 300/800?
How much valve lift are you running?
When you say "idle time", do you mean time the engine runs at idle, or as in sitting idle for 3 months in the garage?
Re: Misc. "roller cam on the street" tech questions [Re: BradH] #597591
01/30/10 12:07 PM
01/30/10 12:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Never used them. K-1100 springs seem to hold up pretty well fwiw.
I've only used the MP gear, and am on my second one since circa 2002.
If you want to spend less than $1000 on lifters, choices are pretty limited. Nothing wrong with 829s or the discontinued Cranes. I've had my 829s rebuilt one time since circa 2002 fwiw. Some here have had good luck with Herbert stuff, never tried it. I have an extra brand new set of Cranes if you want to try them.
With a stock timing cover....weld a piece of plate steel (or even a big washer) to it in front of the cam , and set it up (grind it to the proper thickness) so that it interferes with the back of the water pump, and there's your cam stop. The nylon cam button has the best chance of not putting any extra metal in the oil. I have the Diamond/Mancini button in mine, and it did wear a bit into the timing cover over the first couple years because the cover didn't squarely hit the button. Good thing I keep clean oil in it....lesson learned..next time I'm using nylon.
Rich H.
Esse Quam Videri
Re: Misc. "roller cam on the street" tech questions [Re: 440Jim] #597592
01/30/10 12:25 PM
01/30/10 12:25 PM
Canada
RobR Offline
RobR  Offline
Canada
Holy Cow...3500 miles 6000 miles...!!! That's an awful lot of STREET miles..!! my guys have the springs out of there cars in a 1000 miles.But they REALLY use every bit of rpm there cams make and all the time too.
You guys driving on the hi way with all these miles racked up.
I put spray bars in any engine that I build that is going to see 3000 rpm for sustained periods.
Every set of comp roller lifters I've seen have been DEAD after 2 summers of street use with 275/600..Dirty oil with a bit of valve float I'm sure had plenty to do with it.
The oil in these 700 hp roller street engines is pretty much used up around 250 miles around here.
How hard are you guys driving these engines...
My guys stuff sees their red line 30-40 times a night when they drive them.
I don't think in all the time I've been building these roller engines have I EVER seen a set of rings go 6000 miles up here let alone a set of valve springs last that long
Re: Misc. "roller cam on the street" tech questions [Re: RobR] #597593
01/30/10 03:15 PM
01/30/10 03:15 PM
SoCal
Brian Hafliger Offline
SoCal
The newer versions will last 3 times as long as the old versions!
Brian Hafliger
Re: Misc. "roller cam on the street" tech questions [Re: 440Jim] #597594
01/30/10 05:55 PM
01/30/10 05:55 PM
8secDart Offline
8secDart  Offline
Like 250/700.Lift is in the 650 + 1.6 rockers.I mean idle time at a stop light with the oil hot as hell and idle at 1,000 RPMs.Kills the springs.
