Dodge Mirada #597410
01/29/10 02:23 PM
01/29/10 02:23 PM
USA
b54406barrel Offline OP
USA
I think these cars are neat looking, great factory wheels. Does anyone have an idea what one (1983) of these weighs with a small block, auto, AC, no t-top? Found a one owner, very clean red & white one. Sorry, didn't have camera. Would the big block mounts from a early Cordoba work for putting in an rb engine in this? Exhaust manifolds work or headers? What 8 3/4 rear housing fits? Thank you!
Re: Dodge Mirada [Re: b54406barrel] #597411
01/29/10 02:32 PM
01/29/10 02:32 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I put an 8 3/4 in an 82 Cordoba which is basically the same car. I got a housing from a 68-69 Charger I believe. The pad to pad length is just slightly different but it bolted up just fine. The only thing I had to do was drill out the locating hole on the axle pad to 1 5/8 because of the isoclamp system.
A Mopar magazine did a big block swap into a Cordoba in the early to mid 90's so I think it is possible.
Re: Dodge Mirada [Re: burdar] #597412
01/29/10 02:39 PM
01/29/10 02:39 PM
USA
USA
Are 70 b-body rear ends the same width as 68-69? I worked on a friends, father's Cordoba back in the mid 70's that had some kind of big block motor in it, I thought? Did they not come with b/rb's factory?
Re: Dodge Mirada [Re: b54406barrel] #597413
01/29/10 02:44 PM
01/29/10 02:44 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The Cordobas from the 70's came with big blocks but the 80-83 Cordoba/Mirada only came with /6's and small blocks.
There is an 8 3/4 tech page here on Moparts that gives all the specs by body style and year.
Re: Dodge Mirada [Re: b54406barrel] #597414
01/29/10 03:24 PM
01/29/10 03:24 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Neat cars. Too bad Hurst didn't do a Mirada instead of an Olds. A Mirada with the Lightning Sticks and a t-tops would would have been so cool imho.
Common sense is a flower that does not grow in everybody's garden
Re: Dodge Mirada [Re: b54406barrel] #597415
01/29/10 03:54 PM
01/29/10 03:54 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Here is M-body BB and 8 3/4" swap info, which also applies to J-bodies. V8 cars can use the '74-up B-body spool type BB mounts. Slant 6 cars need the Schumacher mounts.
Big Block M-Body Swap
Chrysler 8 3/4" Rear Axle & Swap Information
Re: Dodge Mirada [Re: Reggie] #597416
01/29/10 04:12 PM
01/29/10 04:12 PM
USA
USA
Wow, those are great links. Thank you! This one is a small block, 318 I assume. I have a friend with a complete '71 340. I suppose I could try playing with that in there. I just have a complete 440 motor/trans & this thing doesn't appear to be real light. Probably no heavier than my '70 rr, though. I never paid much attention to these things but, lowered down like a nascar stance, I think it'd look pretty cool. Plus, the paint/interior is great so for once, I wouldn't have to put a hundred+ hours in painting it!
Re: Dodge Mirada [Re: b54406barrel] #597417
01/29/10 05:16 PM
01/29/10 05:16 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
cordobas 75-79 were B bodies, 80-82 were J bodies (same as mirada, and essentially the same as a 4 door F & M body under the skin).
'68-70 B body rears are almost identical width as the F/M/J's
I have a '68 satellite 8 3/4" in my M body.
if you go big block, do a B block, it fits much better. you may need to use a smaller diameter K car power brake booster.
my 5th ave (same chassis) with HD suspension, A500, 8 3/4, small block with eddie intake, A/C, PS,PB, power windows & driver seat and mustang bullit rims is 3950 lbs w/o me.
2017 Grand Cherokee Overland
Re: Dodge Mirada [Re: b54406barrel] #597418
01/29/10 05:47 PM
01/29/10 05:47 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Drop that 440 in there and don't look back. Member CrAzYMoPaRGuY swapped a BB in a J-body, so you can try sending him a PM. It should weigh around 3400 lbs.
