Fender turn signals.... #597289
01/29/10 01:09 PM
01/29/10 01:09 PM
Halifax, N.S. Canada
Edison62 Offline OP
Edison62  Offline OP
Hello, I'm planning on adding a set of fender turn signals to my 1970 Super Bee clone project. My question is, are they the same style from say 1970 to 1975? Also, would anyone have the exact measurements as to where to drill the holes? Also, looking for the measurements for placement of the 383 emblems on the side of the fenders?
Thanks in advance,
Bryan
Don't be stupid.... it's not smart!
1970 Super Bee. Big blk 4 speed car.
1973 Dodge Dart Sport 340 4 speed car.
1985 Dodge Ram D-100 /6 auto. Original paint
1990 Dodge Ram D-150 V-6 5 Speed. Original paint
1995 Chrysler LHS V-6 auto. Original paint
2014 Ram 1500 R/T 5.7 Hemi...!
Re: Fender turn signals.... [Re: Edison62] #597290
01/29/10 02:20 PM
01/29/10 02:20 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'm not sure about the B-bodies but the E-bodies changed after 72.
Re: Fender turn signals.... [Re: burdar] #597291
01/29/10 02:30 PM
01/29/10 02:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
same on B Bodies... since 73, all with phillips screw on top, more square shaped... earliers with stud and nut, and smooth shaped.
Re: Fender turn signals.... [Re: burdar] #597292
01/29/10 02:31 PM
01/29/10 02:31 PM
IL
71383beep Offline
71383beep  Offline
IL
Same with B bodies.
No experience with 70's, but on 71/72 there were different markers too between Plymouth and Dodge. Dodge had smaller chrome ones that had 2 holes and mounted about 8" in from the nose. The Plymouth used longer painted ones that had 3 holes and were mounted either directly above the wheelwell or about 14" in from the fender on the hood depending on what hood you had. I don't think the 71/72 lights worked for the 70's but am not sure.
In 73 and up they went to a one size fits all wider chrome style that screwed in from the top and used this one for the entire lineup from A to E bodies.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Fender turn signals.... [Re: 71383beep] #597293
01/29/10 03:03 PM
01/29/10 03:03 PM
Edison62 Offline OP
Edison62  Offline OP
I'm soooooooo confused!! LOL!
Bryan
Re: Fender turn signals.... [Re: Edison62] #597294
01/29/10 03:11 PM
01/29/10 03:11 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
You what are the small chrome 70-2 Dodge sigs. All 73 and up A/B/E have the bigger ones with the screw in the middle.
B-E&A #252
http://www.beaparts.com/list_items.aspx?body=B&cat=E&subcat=15
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Fender turn signals.... [Re: moparmarks] #597295
01/29/10 04:39 PM
01/29/10 04:39 PM
Edison62 Offline OP
Edison62  Offline OP
B-E&A #252
Thanks for the link but unless I read it wrong those fit 1970 E body/ 1969 B body / + some "A" body so I'm not sure if they are correct for the 1970 "B" body......?
Bryan
Re: Fender turn signals.... [Re: Edison62] #597296
01/29/10 05:16 PM
01/29/10 05:16 PM
moparmarks Offline
moparmarks  Offline
B-E&A #252
Bryan
Some of his applications are not always accurate.
They fit 70-2 Dodges, some Plymouth A and C-bodies. Never seen them on a Plymouth B-body. I myself don't think they fit any 69 B's.
His ones for 71 Plymouth also fit 72 Plymouths
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Fender turn signals.... [Re: moparmarks] #597297
01/29/10 06:13 PM
01/29/10 06:13 PM
IL
71383beep Offline
71383beep  Offline
IL
B-E&A #252
Bryan
that's the correct style for 71/72 chargers. If they did use them in 70 than it is a fair assumption that this was probably the one.
I don't recall seeing it on a body's though...
