Water Valve 74 Satellite #597244
01/29/10 12:16 PM
01/29/10 12:16 PM
South Carolina
Hawg_Man Offline OP
Hawg_Man  Offline OP
South Carolina
Is there an additional mounting bracket for this valve.......if not how does it mount.....someone put the wrong valve on and am trying to fix with correct valve.
Re: Water Valve 74 Satellite [Re: Hawg_Man] #597245
01/29/10 12:32 PM
01/29/10 12:32 PM
md
mopars4ever Offline
mopars4ever  Offline
md
yes, it is missing the mounting bracket. like this: http://cgi.ebay.com/ebaymotors/NOS-MOPAR...sQ5fAccessories
Re: Water Valve 74 Satellite [Re: Hawg_Man] #597246
01/29/10 01:13 PM
01/29/10 01:13 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Isn't that a 71 only valve for the B's?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Water Valve 74 Satellite [Re: moparmarks] #597247
01/29/10 02:28 PM
01/29/10 02:28 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
this is the water valve my Charger 74 got:
http://cgi.ebay.com/ebaymotors/NOs-Mopar...=item56338cb7ed
aftermarket pieces are available EXACTLY to this one but diff shapped bracket... maybe based on this:
http://cgi.ebay.com/ebaymotors/NOS-73-Do...=item3a54dfd211
classic auto air carries the water valve
Re: Water Valve 74 Satellite [Re: NachoRT74] #597248
01/29/10 02:56 PM
01/29/10 02:56 PM
moparmarks Offline
moparmarks  Offline
Have a couple all original cars with that valve.
Heres a 74 Coronet
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Water Valve 74 Satellite [Re: Hawg_Man] #597249
01/29/10 04:14 PM
01/29/10 04:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Is there a difference between the one for an a/c and non-a/c cars? I know that looks no thing like the water valve in my non-ac 74.
Re: Water Valve 74 Satellite *DELETED* [Re: DaytonaTurbo] #597250
01/29/10 05:12 PM
01/29/10 05:12 PM
South Carolina
Hawg_Man Offline OP
Hawg_Man  Offline OP
South Carolina
Post deleted by Hawg_Man
Re: Water Valve 74 Satellite [Re: Hawg_Man] #597251
01/29/10 05:23 PM
01/29/10 05:23 PM
moparmarks Offline
moparmarks  Offline
This (Mopar 3502346)is for W/AC I believe it has 4 ports as one goes to the AC compressor ...not sure about a non AC valve. I got the number fron my service parts manual.
You might want to double check on that.
And yes that is for 71B's with A/C.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Water Valve 74 Satellite [Re: moparmarks] #597252
01/29/10 05:46 PM
01/29/10 05:46 PM
South Carolina
Hawg_Man Offline OP
Hawg_Man  Offline OP
South Carolina
My Bad........doesn't go to the AC compressor but it is the correct valve without the bracket...with the bracket it is 3502721.
Re: Water Valve 74 Satellite [Re: Hawg_Man] #597253
01/30/10 08:48 AM
01/30/10 08:48 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
bill- rolik has brackets for that valve,at least for e.bodys.dont know if it is the same bracket for b-bodys.
Re: Water Valve 74 Satellite [Re: cuda-sweden] #597254
01/30/10 09:30 AM
01/30/10 09:30 AM
South Carolina
Hawg_Man Offline OP
Hawg_Man  Offline OP
South Carolina
Thanks for the lead.....he did have it (3441883)...I have it on order.
Re: Water Valve 74 Satellite [Re: Hawg_Man] #597255
02/01/10 01:05 PM
02/01/10 01:05 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
no thats not for 73/74 B
Is a generic believe that E bodies are same than 71/72 but thats not true... they only share with 71/72 Bs, but not 73/74 Bs
attached the right one ( actually the one on my car, 74 Charger BB )
73 could get the phenolic Black/Red units but THATS NOT the bracket for 73/74
Re: Water Valve 74 Satellite [Re: NachoRT74] #597256
02/01/10 04:05 PM
02/01/10 04:05 PM
South Carolina
Hawg_Man Offline OP
Hawg_Man  Offline OP
South Carolina
Here is a picture from my CD Satellite manual and it sure appears to be correct.....Don't dispute it sure doesn't look like yours...but also the 3441883 number matches my manual.it's on order so if not correct will return it....thanks for the heads up though.
Bob
Re: Water Valve 74 Satellite [Re: Hawg_Man] #597257
02/07/10 08:41 PM
02/07/10 08:41 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I **believe* this is the bracket:
Common sense is a flower that does not grow in everybody's garden
Re: Water Valve 74 Satellite [Re: Ron_M] #597258
02/07/10 08:41 PM
02/07/10 08:41 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
another shot
Re: Water Valve 74 Satellite [Re: Ron_M] #597259
02/07/10 10:43 PM
02/07/10 10:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeeap, that's the bracket for 73s with phenolic heater valves... maybe some 74s got the phenolic too ? dunno, but I think all 74s I have seen are the brass units.
either way, that brackets has the right shape to the inner fender location to phenolic unit
Re: Water Valve 74 Satellite [Re: NachoRT74] #597260
02/14/10 08:22 PM
02/14/10 08:22 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Anyone know if the phenolic Black/Red units are available? I tried Rock Auto, NAPA, googling to no avail. Is H30-111 or H30-114 a recognizable aftermarket number? Nothing comes up in Google...
Re: Water Valve 74 Satellite [Re: Ron_M] #597261
02/15/10 01:56 AM
02/15/10 01:56 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
It's a 71 E-body valve, didn't think the later B's used that valve...
It's NOT a 71 B-body A/C valve... that I know.
Re: Water Valve 74 Satellite [Re: Ron_M] #597262
02/15/10 05:53 AM
02/15/10 05:53 AM
South Carolina
Hawg_Man Offline OP
Hawg_Man  Offline OP
South Carolina
Look on e-bay ...search "Mopar Water Valve".......about 10 show there.....what year car do you have......is it A/C on not....different valve.
Re: Water Valve 74 Satellite [Re: CokeBottleKid] #597263
02/15/10 07:07 PM
02/15/10 07:07 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The 73 road runner{AC car} I'm working on had the old style{bakelite} valve originally...It has the bracket posted by RonM and there's no other holes on the inner fender suggesting it was ever swapped out...And , as usual its shot... ..Seems they all cracked and probably why they wized up and changed it out... But was'nt that bakelite{or phenolic as some are call it} valve used on trucks though the mid to late 70s ????....Nice part for job security though...
